Speaker Depth for replacements in OEM spots?
Old Apr 29, 2004 | 06:35 PM
afr0puff's Avatar
Supa Dupa Moderator
So there I was in the store about to buy replacement speakers. Some other guy wanted to return his. They were the right size in diameter, but they wouldn't fit because the replacement speakers were too deep. So how deep are the OEM (Bose system) speakers on the coupe?
http://www.anythingbox.net
Old Apr 29, 2004 | 07:02 PM
mvorion's Avatar
Re: Speaker Depth for replacements in OEM spots?
I'm not sure of the exact dimensions, but you should be able to fit most speakers in the front door and rear deck or a coupe without a problem. The rear side panels are another story. You'll need a spacer or fabricate something.
2004 G35C 6MT DG/G | Premium | Alum Pedals |Huper Optik 30/40/50 | Z-Tube | K&N Drop-In | Grounding Kit | Kenwood HU + NAV
Old Apr 29, 2004 | 08:46 PM
bun84067's Avatar
Ditto to the above.
I put in some relatively big Boston Acoustic 6.5's in the front and had no problem. I don't know about the rears as I didn't replac 'em, and don't use 'em.
Old Apr 29, 2004 | 09:22 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
Ditto to the above.
Just for reference, I put Infinity Perfect 6.1's in the front doors (FIT FINE), Infinity Kappa 6x9's in the rear shelf (FIT FINE) and had to settle for Eclipse 6.5's in the rear d/t speaker depth. There has a been a thread about the stock speakers and depths somewhere, can't remember where though. They had pictures of the acutal stock speakers and the measured depth of the back seat side panels. Does anyone remember where this was posted?
doc
Old Apr 29, 2004 | 09:37 PM
afr0puff's Avatar
Supa Dupa Moderator
HA! Those are the exact speakers I was gonna use. Good news!
Old Apr 29, 2004 | 10:53 PM
bkchang79's Avatar
How about tweeter depth? I may use the Seas lotus tweet and those things are long.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
Xfactor
Dec 1, 2019 12:52 PM
mjfenix
Aug 17, 2017 05:49 AM
bTanz
Oct 15, 2015 02:31 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
