07 Sedan, install factory Nav - hypothetical
Old Jul 29, 2008 | 01:12 PM
rpm&my_G35's Avatar
I did a search for 07-08 nav/gps installs and all that turns up for me is 1st gen G35 info so I apologize if this has been brought up.
Let's assume you have obtained a factory Navigation, Display Unit, DVD Unit, Antenna, Switch Assembly and a few brackets (at a reasonable cost).
Are these all the parts you need to swap out on a G35 with premium pkg, non-Nav or are wiring harnesses going to pose a big problem/requirement?
How complicated would this be on a scale of 1-10 if you are someone mechanically inclined and have taken the dash of an 07 G35 apart before?
This question assumes that:
1. do not care about having the rear camera
2. do not care about trunk CD changer
3. do care about adding XM Sat later.
Curious
Old Jul 29, 2008 | 05:36 PM
Gilley's Avatar
I'm not aware of anyone trying it. You can be the first. Be sure to write a DIY to share your experiences.
Or you could get the Garmin GVN-53 GPS unit and use your stock video screen to display the navi using your video inputs.
Old Jul 29, 2008 | 07:12 PM
kool-aid's Avatar
assuming its plug and play with all of the right components it couldn't be that hard
Old Jul 29, 2008 | 08:58 PM
Gilley's Avatar
If it's anything like the nav and no-nav 03-06 sedans, it isn't a plug and play situation.
Old Jul 31, 2008 | 11:00 AM
rpm&my_G35's Avatar
Curious
does anyone know?
Old Jul 31, 2008 | 11:07 AM
GreenGoblin's Avatar
The goblin resurrection
I would start by looking up the part numbers for the wire harness non nav and nav and see if they are different then you will have some insight into what you need to do
Old Jul 31, 2008 | 02:11 PM
grazsrootz's Avatar
where is the nav you revieved from? the 07 and 08 coupe are completely different i believe. anyways, i have a 07 coupe with nav. i am installing a pac aai-nis2 soon. i might be making a guide for removal of 05-07 dash removal with nav next week sometime. i dont know if that will help?
Old Jul 31, 2008 | 07:21 PM
Gilley's Avatar
The OP has an 07 sedan, which is very different from your coupe.
Old Jul 31, 2008 | 07:28 PM
rpm&my_G35's Avatar
good idea...i have downloaded the 07 sedan AV Tech manual so I will check it out.
Jusseth
Sep 13, 2020 12:25 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itztwinki3
Interior
Aug 1, 2015 01:56 PM
trulegend
Audio/Video/Electronics
Jul 31, 2015 03:37 PM
