Any1 ever thought of upgrading the ALternator?
Old Aug 15, 2008 | 08:35 AM
g35coupe253z's Avatar
instead of changing out to a higher performance batteries and getting capacitor u can just get a alternator which is alot cheaper...
Alternator
The Ultimate Choice for Powering your
HHO Fuel Saving System,
Car Audio System, Off Road Lights,
Emergency Vehicles, Compressors,
Winches, Inverters, Welders, Battery Isolators, and more..........
anyway i called Jl Audio and im using a 1000/1 amp and w7 12inch sub i was gonna change the batteries to yellow top optimadrive they told me dont do that just get a alternator u guys should think about doing that its alot cheaper thats if u like saving money :P
Old Aug 15, 2008 | 08:38 AM
Hi-TechG35's Avatar
I am running a 1000/1 and 2 12W6V2's. I have an Optima Red Top and 2 Farad cap. However I have thought about and I am going to upgrade to bigger alternator. I've always done so in the past on my other cars because I am a big audio fanatic. It's so much easier to do in Civics/Tegs though...lol.
Old Aug 15, 2008 | 10:18 AM
CreativeDesignZ's Avatar
H/O alternators are a godsend. i had a custom wound escalade alt. in my I30/Maxima, 250 amps baby =]
Old Aug 15, 2008 | 02:51 PM
The Stimulation's Avatar
With that amp I don't see it as being necessary to upgrade to an HO alt. Alternator's are quite expensive, they are about 300-400, maybe even 500 for a 200A alt. If you're not drawing that much current, it really isn't necessary. The 1000/1 wouldn't need an upgraded alt IMO.
If you want a good battery, I'd recommend going with the Odyssey PC 1200. It's a little smaller than the stock battery, but MUCH more powerful. I used to have a Kinetik HC 1400 and the PC 1200 is a better battery. Voltage didn't drop as much and it maintained more constant voltage. I was actually searching the other day for the PC 1200 and found a site for 192 shipped, which is a great deal.
I'm wondering if the PC 1500 would fit, but it might be too long. If it does fit, I'd get that instead. But running about 1k of power won't really require an HO alt, especially if you are playing your music at a conservative level, not blasting it all the time. I have friends with Optimas and they like em, others have moved away from them. Kinetiks are good batteries but better for competition since the vehicle is off. Hawker/Odyssey/Stinger are all made by Enersys and are excellent daily batteries. With that and the Big 3, you should be fine.
Don't worry about dimming, be more concerned about voltage. If you're staying around 13V while the vehicle is running and hitting low or current drawing notes, then you are fine.
Old Aug 15, 2008 | 07:59 PM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
If you still feel the need. Try www.ohiogen.com They've been helping sound off competitors for YEARS....
Old Aug 15, 2008 | 08:13 PM
2drwild's Avatar
ty for the link...
Old Aug 15, 2008 | 09:21 PM
A couple others...
www.qualitypowerauto.com (I used theirs for my Accord).
And another one recently I've heard of http://www.mechman.com/alt.htm
I've also had friends use Excessive Amperage and had great success. http://www.excessiveamperage.com/
Old Oct 10, 2008 | 01:51 AM
thebayg35's Avatar
i have a 1000/1 jl audio to 2 jl w6v2s and when i knock real loud it cuts off at low end power =\ im worried that getting a cap will just mask the issue.. do you recommend upgrading the alternator
Old Mar 10, 2009 | 07:47 PM
dreamweaver's Avatar
Go with these guys I did and im very happy www.dcpowerinc.com
220 amp pulls 130 amps at idle and comes with a nice black billet overdrive pulley. all for 440 bucks delivered... its a quality piece and im pickey.
wuzz-upp
Oct 3, 2015 04:21 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
