Best place to put a DVD player?
Old May 8, 2004 | 08:20 PM
G352NV's Avatar
Never enough
Whats the best place to put a small DVD player. My coupe has NAV so I cant put it in the nav box. Any ideas are welcome.
Old May 9, 2004 | 02:22 AM
ikSardarG's Avatar
Re: Best place to put a DVD player?
Many users here have placed it in the arm-rest on the back seat. It simply involves taking out the first aid kit....
**** Official PAC Aux Input Dealer!!! ****
PM me for more info...
Navi-Conversion Kits at Discounted Pricing
*Authorized AV Electronic Dealer*
Old May 9, 2004 | 08:28 PM
jasijay's Avatar
I used the top most glove box with some modification. This way I have access to it when I need it if I should want to change the DVD during a ride.
03 Sedan, White on Black.Clear Corners, Stillen Exhust, Grounding kIT & High Flow box, .Z-tube, 18'' XS Style, Eibach Pro-Kit.
Old May 9, 2004 | 09:58 PM
Tybrey's Avatar
Get a 10 disc DVD changer and place it in your trunk. That way you don't have to worry about changing disc.
http://www.avelectronic.com/10DVDChanger.htm
"Not all G35 owners are G35 Drivers"
2004 G35 Coupe 6MT-BS/BLK | Full Aero-Navi | Gounding Wires | Clear Corners | 35% Tint | 350Z Tube | JWT PopCharger | Passport 8500 |
Old May 9, 2004 | 10:29 PM
RamboRami's Avatar
G35driver.com Moderator
i would get one mounted under the glovebox where the black foot panel is
1) you can access it from the inside of the car. no need to go to the trunk.
2) wiring it to the nav screen will be super-easy.
3) you can use a regular dvd-remote to control the movie that is playing.
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
Old May 9, 2004 | 10:35 PM
KPierson's Avatar
I'm in the process of putting my DVD player in my center console of my 04 coupe. When you lift up the arm rest it will sit right there. My first attemp I took the DVD player apart and just tried to mount the guts, with just a fiberglass panel covering it with a slot cut out. Unfortunately I didn't line it up perfectly and it messed up the motor and I had to get a new DVD player. This time, I am mounting it vertically with the original front on it. The only problem is that the air bag controller is in the way and will have to be moved slightly to get the needed depth. I'll post pics if I ever get it done....
Kevin
04 Diamond Graphite Coupe - FULLY loaded
Windows up with OEM Remote
RE Short Shifter // Z Tube
Old May 10, 2004 | 06:52 AM
1bern's Avatar
Well we have an armrest in the backseat. I can't seem to find mine. I saw the red button in the center of the back seat and thought this was a release for the armrest, but this seems to pull the whole seatback down. I'll have to look again.
Old May 10, 2004 | 02:55 PM
djrobx's Avatar
I think the Sedans have armrests, the Coupe's don't. I guess they figure people getting stuck in the back of a Coupe are getting the shaft anyway, why bother with an armrest?
-- Rob
Old May 10, 2004 | 06:44 PM
spmc's Avatar
I installed mine under the glove box. Like Ramborami said, it was very easy to hook up to the AVelectronic box and power because it is close to everything.
It's pretty easy to access from the drivers seat, but I have yet to spend over 2 hours at a time in the car so I have not needed to swap movies while driving.
Like previously mentioned, the remote control works directly on the player, so there was no need to install a remote sensor.
One thing I did not like was seeing the player hang down below the glovebox in plain view. I went to the local fabric store and bought some vinyl just about the same color as the willow interior. I cut a strip about 3 inches wide and 2 feet long or so and used velcro to secure it under the glove box across the entire underside of the passenger dash. It hangs down like a small curtain just low enough to cover the DVD player. It's not perfect, but most people looking from outside the car never catch that it is not part of the car's interior . . . and it certainly beats the look of the DVD player just hanging down there. If you have black interior you could match the color even closer and probably make the curtain almost invisible.
Old May 13, 2004 | 03:19 PM
bamadog's Avatar
Black 2004 G35 6MT, chrome wheels, black, still pristine
Or to give it a more professional look, so the fabric isn't AT ALL wavey or wrinkled in spots.... is to just mount the fabric on a piece of pressed/plywood that would fit under the glovebox - oh, about 2-3 inches I presume - whatever makes you happy. Then either velcro the wood to the front of something OR put a hinge or 2 on the top of the wood so the new "door" flips up or down.... in any case, when glueing or tightly stapling the fabric down, it won't look like a curtain. Stretching the fabric all the way around the wood, then stapling on the back of the wood might be your best bet if you just want the front to look good.
my .02.
The Bamadog
BAMADOG.COM
2004 G35 Coupe - Black/Black 6MT - Chrome 7-Spoke Wheels - Aero Kit & Package w/spoiler - Tint - Alpine System - Body Side Molding
Old May 13, 2004 | 04:29 PM
RamboRami's Avatar
what about the infrared sensor on the dvd-player.... how would the dvd-player receive the signal from the remote?
I think the best alternative would be to get black cloth or vinyl, no matter what color interior you have, and a black dvd-player, that way you can cut a hole where the infrared sensor resides... and it wont look too obtrusive!
i win!
Frostbite91
Aug 20, 2015 07:20 PM
Higbee89
Aug 16, 2015 09:36 AM
crazy_g35s
Jul 20, 2015 02:30 PM
Jadenkid22
Jul 14, 2015 12:33 AM
