Add-On Dual Climate Control
Old Aug 25, 2008 | 01:15 PM
G'sUpHosDown's Avatar
I've got an '05 G coupe. Its the base model without the Dual Climate Control, homelink or auto-lights.
Is it possible to add the Dual Climate Control by adding the button and switch as is the case with the Double-Din install? I was hoping to solder the LED and switch and snap in the button.
Any thoughts? I've searched but got nothing
Thanks
Old Aug 25, 2008 | 03:26 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
should be able to do that if you find the 05-07 LED and DCC button for the AC controller....
doc
Old Aug 25, 2008 | 05:03 PM
awesome. as long as i don't have to mod the dash display or computer, it'll go for it
Old Aug 25, 2008 | 05:28 PM
miltoda's Avatar
don't you think there's more to the dual climate system other than a button. If that was the case, it'd cost infiniti less to just make it standard. I'm sure there some mechanical difference in the baffles the AC system uses to be able to blow air at different temps in two zones.
Old Aug 26, 2008 | 09:54 AM
can anyone confirm a difference in the ac system?
Old Aug 26, 2008 | 10:39 AM
Shakuya88's Avatar
How about try it and let us know if it works? how much can and LED and little push button cost...$5. Give it a shot.
Old Aug 26, 2008 | 11:40 AM
is there an online catalog? maybe the part numbers are different/same for the ac system components
Old Aug 26, 2008 | 12:28 PM
miltoda's Avatar
I looked through trademotion.com and the only difference I could find is the dash control unit that is different for non-prem and prem Gs.
Mechanical Catalog - 2006 - Infiniti - G35
Hvac, Controls, Controls, Dash control unit, Dash control unit, g35, w/premium pkg. $295.68
Old Aug 26, 2008 | 12:51 PM
on riverside infiniti's site there are 2 heater cores listed. one for premium and one for non premium. does anybody know the differences there?
Old Aug 26, 2008 | 01:21 PM
Shakuya88's Avatar
most likely dual climate cabability
Old Aug 26, 2008 | 01:52 PM
yea, there appear to be 2 separate heater boxes for premium and non. i'll have to start looking in the junkyard, ebay etc
Old Aug 26, 2008 | 02:44 PM
Shakuya88's Avatar
GL, i have DCC and don't use it too much. Don't see why everyone wants it so much.
Old Aug 26, 2008 | 02:59 PM
OBG3506's Avatar
jsut thinking in order to use DCC contral especially if you have a chilly all the time gal you would need two of everything (ac/heat) cause with a 70/85 split its a lil more than adding in a lil engine temp! just a thought!
Old Aug 26, 2008 | 03:36 PM
Shakuya88's Avatar
That explains it...no gal in the 4 months I've had the G. I rarely use the HVAC at all. Only when raining and windows cant be open. For cold I use Heated seats.
Old Aug 26, 2008 | 04:26 PM
10nara's Avatar
its a completely different system, its not going to work. This question is like asking "Can I get Bose sound by sticking Bose emblem on my speaker covers?"
