Blown stock bose speakers
Old Sep 9, 2008 | 05:31 PM
cwylie's Avatar
Can any one reccomed replacments? I dont want to rip out the entire stereo just replace the speakers.
Old Sep 9, 2008 | 05:41 PM
Gilley's Avatar
If your car has a warranty, they will be replaced for free. Otherwise, you need 2 ohm speakers.
Old Sep 10, 2008 | 03:58 AM
roots4x's Avatar
Infinity has a lot of 2ohm speakers if you're having trouble finding them. Crutchfield has excellent data on speakers they sell and have great service and support. They will also tell you what speakers you need and what will work in the car.
One thing to note is that you should buy speaker spacers (1" MDF) because the stock speakers stick out an inch from the sheet metal. You can buy ones specific for the G35 from ebay. Look up G35 speaker spacer. A seller named zenclosures should have them. The spacers move the speaker up right to the grille which have a foam surround on it so that you don't lose any sound in the door panel.
Because crutchfield assumes you're mounting the speakers right on the door with the cheap thin plastic adapter rings they send you, some speakers that Crutchfield doesn't approve should actually be OK. In fact, the front doors can hold pretty much any 6.5" driver. The back has a little less clearance, but it's somewhere at around 2.5" mounting depth if you use the 1" spacer.
Old Sep 25, 2008 | 04:59 PM
cwylie's Avatar
are the rear 6x9 just a wolfer or a 2 way speaker?
Old Sep 26, 2008 | 12:11 AM
roots4x's Avatar
Just a woofer. The rear side speakers are full range, but 1 way. The front speakers are the only 2 ways.
Old Sep 29, 2008 | 07:00 PM
cwylie's Avatar
I got some standard 6x9's to replace the rears. Wonder how its going to sound. Any way to make them full range?
EnCr1pt3d
Jul 8, 2019 02:48 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
Tyler's03G
Aug 13, 2015 10:04 AM
Frostbite91
Aug 2, 2015 04:59 PM
