GPS antenna mounting? Where is the factory antenna?
Old Sep 17, 2008 | 09:26 AM
blazeplacid's Avatar
I recently bought a G35.
I have A Kenwood DNX8120 I want to put in. I have all the stuff to install the unit.
Where is a good place to mount the GPS antenna? Any ideas on the location of the facotry GPS antenna (for those who do have factory nav)
Also, any ideas on the location of the reverse wire?
Old Sep 17, 2008 | 11:07 AM
lancer's Avatar
I second that.
I will be curious as to where the reverse / speed sense wires can be found as well...
Old Sep 17, 2008 | 12:17 PM
Noremac's Avatar
Originally Posted by blazeplacid
Any ideas on the location of the facotry GPS antenna?
It's behind the clock/temp display finisher piece. See attached pic from the FSM.
Attached Thumbnails GPS antenna mounting? Where is the factory antenna?-temp-gps-pic.jpg
Old Sep 17, 2008 | 02:07 PM
roots4x's Avatar
I mounted my external GPS antenan in the stock location. You'll have to take some silicon glue or something and attach it to the plastic part of the dash. It'll be easily removable but will stay in place. That bracket you see is not actually there if you don't have the stock nav, but you might be able to fabricate one. I didn't have the tools or time to do anything like that so i just glued it in.
Old Sep 17, 2008 | 02:16 PM
lancer's Avatar
sweet action, thanks for the pic.
any idea about the speed/reverse wires...?
Old Sep 17, 2008 | 03:05 PM
yeah thats what I need to
also, is the radio "slot" pretty big? Im talking about where the back of the radio goes, how deep? Any problems with double dins not fitting?
Old Sep 17, 2008 | 03:37 PM
Vegas79's Avatar
The fitment can be pretty tight. Just make sure the wires tuck neatly inder the unit.
I had to make sure that all of the wiring sat under the radio for it to properly fit. Otherwise you could end up pinching wires against the back of the radio and the dash wall.
The speed wire I pulled from behind the radio. I think it was a green/white wire. What year is the car?
I never hooked up the reverse wire.
Old Sep 17, 2008 | 06:49 PM
Gilley's Avatar
I moved my Kenwood GPS antenna from under the rear window to the factory location and the reception is so much better. I made a bracket out of a flat piece of metal that I bent and screwed into place.
Old Sep 17, 2008 | 11:04 PM
lancer's Avatar
Mine's an 04, aside from driving the car with a disassembled dash holding a multimeter to random wires, is there any way to know for sure?
I'd think they've gotta list that sort of thing somewhere.
Reverse wire will be important, I'd like to do a backup camera with the Z1. I just keep finding more crap to buy for this *($# install.
Apologies for the thread hijack. I will give it back eventually.
Old Sep 18, 2008 | 01:44 AM
roots4x's Avatar
The wires are listed in the service manual. try infinitihelp.com
Old Sep 18, 2008 | 08:09 AM
nah no problem, I need all of this info also
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
TurTLe*
Sep 29, 2015 01:43 PM
Claudiu
Sep 26, 2015 01:04 PM
