wtf do i do this these wires(harness)
Old May 17, 2004 | 05:16 PM
nuttyprof's Avatar
ok guys, this is a dumb questions probably, but i got my Scosche harness NN03 and there are wires that come out. umm, what do i do with them? i have another connector that fits into my aftermarket headunit, but which wires go to which hole? omg this is insane!
G35s6mt/TSecu/350Z Springs&Struts/K&Nfilter+Z-tube/StillenDualExhaust /6WireGroundKit/KinetixHighFlow
Old May 17, 2004 | 06:06 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
Re: wtf do i do this these wires(harness)
ok......
Using wire crimpers and connectors listed in my DIY, follow the color coding on the NN03 and your aftermarket deck wire harness that came with the deck. Match up the colors and start crimping away.....
I don't remember what your exact setup was going to involve so I'll try to describe all the scenarios....
1. aftermarket deck + aftermarket amp = only need NN03 power (power/ground/ACC/powered antenna) wire harness, NO NEED for NN03 speaker wire harness since you will be running RCAs from the deck to the amp.
Crimp power/ACC/ground/powered antenna wires together from your deck's wire harness to the NN03's harness.
Tape up the other "open" wires. Throw the NN03 speaker harness in your junk drawer.
deck <- plug <- deck's power/ACC/ground/powered antenna wires <-> crimpers(CONNECT AND CRIMP HERE) <-> NN03's power/ACC/ground/powered antenna wires -> NN03 plug -> stock harness plug -> stock power/ACC/ground/powered antenna wires
2. aftermarket deck + STOCK amp (using stock amp signal wiring to trunk) = power wire harness AND NN03 speaker wire harness. Just match the wire colors for the NN03 speaker wire harness and the deck's speaker wiring and crimp. This NN03 speaker wire harness will plug into the stock speaker wiring harness which will send the signal to your STOCK amp in the trunk.
**remember you have to find the remote amp lead wire (blue/white stripe) from the deck to the stock wiring and crimp it together and connect the remote amp lead wire in the trunk's wire bundle to your amp's remote power terminal ( I couldn't find the remote power wire in the trunk after trying to crimp every combination blue/white wire)
OR
run your own remote amp power lead wire from the back of your new deck to the trunk to your amp's remote power terminal. (this is what I ended up doing when I couldn't find the stock remote power wire).
IF YOU DON'T CONNECT THIS REMOTE AMP POWER WIRE from your aftermarket deck to your aftermarket amp, YOUR AMP WILL NOT TURN ON......
Hope this helps...
docron1
Old May 17, 2004 | 06:46 PM
ikSardarG's Avatar
Wow Joe. Helluva reply. Good work.
**** Official PAC Aux Input Dealer!!! ****
PM me for more info...
Navi-Conversion Kits at Discounted Pricing
*Authorized AV Electronic Dealer*
Old May 18, 2004 | 12:20 AM
RamboRami's Avatar
G35driver.com Moderator
heh nice reply, to sumarize...
This is how they all connect:
Factory Harness >> Scoche NN03 Harness >> New Headunit's Harness
The reason you bought the Scoche harness is so that you dont have to tap into the Factory harness wires, so instead, you will tap the headunit harness wires into the Scoche Harness wires (using a crimper, or just twist and tape up w/ electrical tape)
You will use 2 of the 4 stock harnesses, the other 2 you will just tape together and stuff away behind the ashtray.
The vehicle speed-sensor wire is the white/green wire in one of the unused stock harnesses (incase you have an aftermarket Navi)
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
Old May 18, 2004 | 01:09 AM
nuttyprof's Avatar
oh yea, i figured it earlier today. thanks so much man. awesome write up. this should help lots of people like me. ill take so0me pix when im done.
Old May 18, 2004 | 02:24 AM
richie's Avatar
does the NON-BOSE G's have a stock amp?
Old May 18, 2004 | 06:44 AM
docron1's Avatar
Again, the correct terminology should be "Premium" or "non-Premium".....
The PREMIUM system has stock Clarion deck, 6 stock speakers WITH the addition of the Bose amp and the rear shelf 6x9" "subs".
The NON-PREMIUM has stock Clarion deck and only 6 stock speakers. NO Bose amp or rear shelf subs are installed in non-premium......
<P ID="edit"><FONT class="small"><EM>Edited by ramborami on 05/18/04 08:00 AM.</EM></FONT></P>
Old May 18, 2004 | 10:59 AM
RamboRami's Avatar
the "stock" amp is the Clarion headunit which bumps 160 watts peak (powering the 6 speakers in the car, 2 front+ 2 tweeters, 2 rear-side panel)
Old May 18, 2004 | 05:40 PM
docron1's Avatar
sorry rambo, I was grouping the fronts (6.5" and tweets) as 1 speaker set. I guess they are two speakers.... thanks...
docron1
Old May 19, 2004 | 04:13 AM
chenga's Avatar
Let's not forget that the sedan actually does have a "sub" or rather a "bass boosting Nd woofer." I think someone said an 8"?
Nd is the element neodymium, which is a fairly common metal used for speaker magnets.
Old May 19, 2004 | 03:05 PM
nuttyprof's Avatar
my sedan has no nd woofer. at least not one that ive seen. no premium.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
the93owner
Sep 28, 2015 10:37 PM
vamarris
Sep 26, 2015 12:56 PM
