went to car toys today
Old Oct 17, 2008 | 06:14 PM
qazqaz3's Avatar
Question went to car toys today
so i just bought a clarion MAX685BT and NAX980HD. now i need to get that installed and i want to be able to hook up my xbox and stuff up to it so this is what they quoted me
i would need these parts...
1. antenna adapter from eale -$14.99
2. harness from eale -$17.99
3. vgp1 from amin -$14.99
4. univ stering wheel from pacc -$84.99
5. adjustable line from pacc -$44.99
6. misc LA -$250.00
7. parts charge -$25.00
8. double din -$189.99
9. special orders -$10.00
10. mis LA -$80.00
11. parts charge -$8.00
total $740.94 + tax
now something just doesnt seem right here
i think the misc LA is wire and in house parts
the adjustable line he said is cuz with out it the max volume would be 15
the univ stering wheel is so i can still use my stering wheel controls
...but what do you guys think
thanks
p.s. its 04 g35 coupe
Old Oct 17, 2008 | 07:11 PM
DHCrocks's Avatar
I've got the previous generation which is the MAX675 and the line out's are low. I think the're less then 2v. I'm running a Alpine PDX 2.150 and 1.1000 and the gains needed to be adjusted to max and it's still not enough. A line driver would help but it's not necessary. it'll work fine, just may not get the volume you expect. I usually listen at about volume 19 to 23 if I turn it up to 24 then you can start to hear some distortion coming from the HU. from 0 to 10 you can't really hear anything. If you like it loud then yes get a line driver.
don't forget the ipod adapter.
Old Oct 18, 2008 | 07:30 AM
acarnes83's Avatar
The double din kit that Cartoys has access to is absolutely hideous! I had an '04 sedan (coupe and sedan use the same kit) that I was going to have about 3 grand in equipment installed in, they ordered the kit, I saw what it looked like, and I told them thanks but no thanks. The problem is the AC controls. Instead of being hard plastic they are a very low end looking soft rubber. Also, unless you have the lighter colored interior the buttons won't match, as they are light gray. If you really want to go double din I would suggest purchasing the double din finisher and JDM AC controls from Grubbs. It will cost you a bit more, but your car won't look like *** when it's done.
http://www.grubbsperformance.com/ser...UPE%3AINTERIOR
Also, if I recall correctly, misc LA is the labor charge. When I was going to have my work done I made them explain every line item to me in detail.
chinee
Jun 10, 2024 07:48 PM
ghost_g35
Aug 7, 2015 10:31 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
DRG35R
Jul 31, 2015 10:23 AM
ClwMike
Jul 23, 2015 12:55 PM
