Installed an aftermarket HU in my sedan but now the system is not as loud???
Deezflip,
Thanks for the info, i didnt see your replies before my last post.
I'm going to try the SCOSHCHE hardness and see if that makes a difference, if not I'll just follow your advise to bypass the amp and just run speak wires to the trunk and connect them to the speaker cables going into the amp... I'll post the results
Thanks again
Thanks again
I just found out that this line out adjuster may help.
http://www.discountcarstereo.com/detail.aspx?ID=753
has anyone use it? for $30 shouldnt be a bad route to go with moving on to a more expensive solution.
Originally Posted by naughty240
A quick painless bypass would be to remove the harness and wire the pre to the post wired speaker wires. You would lose the sub though.
A complete bypass was what I was leaning toward in my other post in your other thread. Get all the Bose crap out.
You wouldn't want to connect a pre-out to an actual speaker. You'd have to used the amplified outputs on the HU instead.
Not yet L7nx,
I already ordered this online http://www.discountcarstereo.com/detail.aspx?ID=753 but i should be getting it tomorrow or monday. I will post results once I install it.
i have the same problem, i just installed a d3 and the sound coming from my bose speakers are horrible. i have the 2 wire harnessess with the rcas. If i just go ahead and change the speakers will i get better sound? or would i need that wiring harness without rca's. the sound the bose speakers gave with the bose headunit was great, im not looking for a really amplified sound, just one that is able to keep up with the bose speakers. If all i have to do is change the speakers then i will go and pick up infinity reference 6.5 and 6x9. any help is appreciated
i found the solution to all our problems. get the metra harness no. 70-7550, the one for nissan 1995-2005. It is all wires instead of the rca wires. Now my D3 is on volume 9 and it sounds very loud. The rca wires u have william act as a converter and it messes up the frequencies that the bose speakers and amp give. Get that metra harness and replace it with the one with the rca's. fastest and cheapest way to maintain your great bose sound with an aftermarket headunit. IM ****IN HAPPY I GOT MY SOUND.
this is the harness
http://www.installer.com/photos/70-7550.jpg
this is the harness
#30
