Installed an aftermarket HU in my sedan but now the system is not as loud???
What's up guys?
I just installed a Pioneer Avic-F900BP in my 2003 Sedan (Bose system equiped). I used the Metra hardness 70-7551 to installed the radio and everything works perfectly
Now, even though everything works great on the radio, i noticed that my system is not as loud as the stock HU anymore. Even at the Avic's Max volume you have to drive with the windows up while driving on the expressway to be able to hear the songs otherwise you can barely hear it. I remember with my stock radio, I rarely (if i ever) cranked up the volume to its max from how load it was... any ideas on how I could increase the volume on my system?
The bose system is expecting differential signals for the left and right audio. Does this HU have the same output? Does it have the same peak-to-peak amplitude as the factory HU? Some things to check out. Also, the bose is 2-ohms but that shouldn't make a difference since the bose amp is still in the trunk.
I had this same problem. I eventually swapped out the bose amp for an aftermarket one.
Anyway, I think this is why people go with the scosche line converter so they have the option to adjust and tweak the low-level output gain.
The metra or even a direct connection to the rca's has set level/gain which may not be enough for the bose amp. Even if it was enough, it might be looking for "balanced" signals which further complicates the compability.
It's just a pain in the a$$ to make any aftermarket equipment work with Bose.
Do you think it'll make a difference? I mean I dont mind giving it a try but i went with the RCA hardness because supposetly the ones without it create a humming noise (dont what is to call it LOL)
blklude98
What's a line driver? the getting another HU isnt really an option for me since i already bought the one i have and cant return it (not without a restocking fee that is)
Originally Posted by blklude98
it's because the Pioneer has WEAK preout voltages...you can get a line driver or a headunit with at least 5V preout voltages.
http://www.sonicelectronix.com/item_...ix+-GRAY-.html
I dont mind giving it a try if its going to help me out to increase volume
I have the exact same problem. I installed a kenwood ddx6019 a week ago and it does not get nearly half way as loud as my stock sterio would. its depressing because my stock sterio would get a lot louder, with the windows down, its hard to hear music on the kenwood HU, any help would be appreciated
Well its satisfying to know there are solutions, but i'm just curious why this hasnt happened to everyone else who installs double din units? I'm thinking they go alot, new subs, amps, and in our case, we are settleing with the stock bose other then the HU. After a few pm's with Gilley, he is very knowledgeable about audio components, i dont know **** about, and i gues its very complicated when it comes with messing with the bose.
one thing my friend suggested who installed my unit was to splice into the factory amp/sub harness tothe HU, rather than use RCA? i'm clueless about wires,etc, so i dont know if this might work or make sense?
The reason for not everyone having the same problem is because not all radios have the same preout voltage (in my case the Pioneer Avic-F900BT puts out 2.2V) so depending on what other guys are using they may get better results.
And going with your friend's advise, that means that you'll have to use a hardness like this one:
rather than using one with RCAs for speakers like the one I've used (shown on the my original post)
I'm still trying to find what is the quickest solution for this. I may go with the SCOSCHE adapter but not final yet. Whatever info I find out i'll share it with you.
Originally Posted by williamjv
Is this the one you're talking about?
Do you think it'll make a difference? I mean I dont mind giving it a try but i went with the RCA hardness because supposively the ones without it create a humming noise (dont what is to call it LOL)
I did spend additional money on cables and RCAs just to power the Rockford It's just a domino affect with upgrading the stereo.
You might have to run speaker wires from the headunit to tap into the speaker leads by the bose amp(completely bypass the bose amp). You might have to lose the fadar option this way, since you have to wire them in series to get 4ohms. 4ohms will keep your headunit amp stable.
good luck
