G35 Bose System
Old Nov 14, 2008 | 02:50 PM
daveug35's Avatar
G35 Bose System
I already posted this in the general g35 coupe section, but I should have posted here, since this is the place for it, my apologies.
I have a 2003 G35 coupe with the all black bose radio. I need to have it replaced, and do not want to pay the dealer 700 to put a refurbished one in. My first question is, is this definitely a bose radio? It says bose on it, but I've read different things about clarion making some radios and bose just being the speakers. I have the all black trim, not the silver, if that differentiates the two. My second questions is, do I need specifically a 2003 radio, or will a 2004 bose radio work. Thanks.
Mine has an SAT button as well.
Old Nov 14, 2008 | 03:02 PM
MR. WOMO's Avatar
dave,
I am going to assume that because you say you need another radio for your G, the original one has failed. My first question is - do you (or the dealer) know WHY it failed. If you take a half hour or so and look around this section of the forum, you will read about many, many, many people that have had a lot of issues with their OEM radios. This primarily due to a common, badly-engineered circuit board on the G. Should this be the case for you, I would heartily suggest that you think about replacing the radio (which is a Clarion model I believe, not a Bose one) with an aftermarket double-din unit, along with the dash fascia and climate controls.
Read through this section for a while and let us know if you have more questions or concerns.
Cheers,
Kev
Old Nov 14, 2008 | 03:06 PM
nghiars's Avatar
i would go aftermarket to avoid tis isse again.
Old Nov 14, 2008 | 03:19 PM
daveug35's Avatar
For the last few months, my battery was getting drained. I read up on the problem, and decided to take out the fuse for the radio/ac. Over a month with no battery dying (obviously no radio and ac controls). I put the fuse back in, and the car was dead within a few days. I went to infiniti and told them that the circuit board on the radio was draining my battery, and they told me they needed to run a diagnostic. Today they tell me it's not the circuit board, but rather the radio itself that needs to be replaced, which is supposibly a different issue than the ones many others were having with their radios. They want 700 for a refurbished one, which is ridiculous. I'd replace it with an aftermarket if I have to go that route.
Old Nov 14, 2008 | 03:33 PM
MR. WOMO's Avatar
This would be my opinion only, but I'm sure they told you that to A.) avoid you getting into it with them in regards to the whole sh*tty circuit board issue that they know is the real problem but don't want to admit; and B.) get you to waste your money on another one of their sh*tty radios.
Gladly, it sounds like you have the brains not to go that route. Given that situation, you have a lot of research to do in regards to what kind of headunit you want (features, price, make, din size, etc.) fascia pieces; that sort of thing.
This forum is invaluable in not only information about that, but a lot of DIY threads detailing how to go about installing it yourself should you want to do so.
Good luck and have fun!
Cheers,
Kev
EnCr1pt3d
Jul 8, 2019 02:48 PM
mjfenix
Aug 17, 2017 05:49 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
BlackGee35
Jul 21, 2015 07:24 PM
