Alpine SWS-1043D vs JL 10W3V3
Old Nov 17, 2008 | 07:58 PM
clokwork's Avatar
Cmon Son!
I have a 250 watt class D amp to push either of these subs. I want a single 10" woofer for a separate car (not the G) which would you suggest. I have narrowed it down to these two.
images taken from crutchfield.com
Old Nov 17, 2008 | 07:59 PM
clokwork's Avatar
Cmon Son!
Jl Audio:
Size 10 -inch
Impedance 4 ohms
Cone Material Mineral-filled poly
Surround Material Rubber
Sealed Box Volume (cubic feet) 0.625
Ported Box Volume (cubic feet) 1.125
Port diameter (inches) N/A
Port length (inches) N/A
Free-Air No
Dual Voice Coil No
Sensitivity 84.87 dB at 1 volt
Frequency Response 25 - 250 Hz
RMS Power Range (Watts) 100-500
Peak Power Handling (Watts) 1000
Top Mount Depth (inches) 5 7/8
Bottom Mount Depth (inches) N/A
Cutout Diameter or Length (inches) 8 15/16
Vas (liters) 32.23
Fs (Hz) 31.49
Qts 0.485
Xmax (millimeters) 14
Parts Warranty 1 Year
Labor Warranty 1 Year
Alpine:
Size 10 -inch
Impedance 4 ohms
Cone Material Glass Fiber & Pulp/Kevlar
Surround Material Santoprene rubber
Sealed Box Volume (cubic feet) 0.65 - 1.5
Ported Box Volume (cubic feet) 1 - 1.75
Port length (inches) 14
Free-Air No
Dual Voice Coil Yes
Sensitivity 84 dB at 1 volt
Frequency Response 31 - 700 Hz
RMS Power Range (Watts) 50-300
Peak Power Handling (Watts) 900
Top Mount Depth (inches) 4 1/4
Cutout Diameter or Length (inches) 8 7/8
Vas (liters) 30
Fs (Hz) 34
Qts 0.68
Xmax (millimeters) 12.8
Old Nov 17, 2008 | 10:39 PM
The Stimulation's Avatar
W3 between those two.
Old Nov 18, 2008 | 03:07 AM
clokwork's Avatar
Cmon Son!
I was hoping for that answer. since it seems 300 watts is the sweet spot for the W3, I was slightly worried that 250 wouldn't cut it.
Old Nov 18, 2008 | 09:21 AM
You won't notice the difference between 50 watts, so its not that much of a big deal.
Old Nov 21, 2008 | 01:12 AM
clokwork's Avatar
Cmon Son!
Sweet. I appreciate that!! 10W3V3 it is!!
Picture Share
Feb 4, 2018 12:41 PM
Frankieg35
Oct 7, 2015 10:22 AM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
tig488
Aug 18, 2003 02:05 PM
