How To Install A Sub In A G sedan Using Stock Bose System
Rating: Thread Rating: 3 votes, 5.00 average.
Old Sep 30, 2014 | 02:21 PM
  #241
cdub0619's Avatar
I'm using the PAC SNI-35, it's two channels and adjustable for gain. The amp also has bass boost, by pass filter. The audio shop said all the settings on the amp and LOC and wiring of the sub were correct it's just not getting a full signal with the wires it was connected to. With16 pages of repeated success I found it odd that I wasn't experiencing the same thing.
Old Dec 2, 2014 | 03:04 PM
  #242
jeza's Avatar
Did u connect the brown plug back to the stock sub to power it up or no? and why
Old Dec 2, 2014 | 03:16 PM
  #243
MotoCARR's Avatar
G35 Sedan
Brown wires are not needed.
Manual from Rockford Fosgate's site(Who made Install Edge back in the day)
File Type: pdf
Old Dec 2, 2014 | 03:29 PM
  #244
jeza's Avatar
i mean did u connect the plug back to the stock sub woofer ?
Old Dec 2, 2014 | 03:33 PM
  #245
MotoCARR's Avatar
G35 Sedan
Nope, no reason to have the stock sub connected still
Old Dec 6, 2014 | 01:48 AM
  #246
Mishalbadboii's Avatar
Smile helppp!!
If I connect the L+R rca cables to the amp, less bass coming out of my single 12" Kenwood subwoofer. But if I connect only one RCA (left or right doesn't matter ) to the amp, sub hits harder and perfect.
So do you know what's the issue or should I leave one RCA connected and listen to my music ?
Old Dec 13, 2014 | 03:58 PM
  #247
Orioles's Avatar
When running an aftermarket amp + sub. all thats needed for the amp is RCAs and remote turn on from the head unit to the amp? or should i use a LOC and get everything at the factory amp
Old Apr 13, 2015 | 07:33 PM
  #248
drdaniel41's Avatar
kills battery
hi all, I've searched the thread and found no similar problem, and if this is a repeat, I apologize. Anyway, i hooked everything up exactly like you did, only difference being my loc required, power, ground, and remote power. It kills my battery overnight, wondering if the wiring to my loc is a possible problem? Thanks
Old Apr 13, 2015 | 07:48 PM
  #249
Wrathernaut's Avatar
Gentle Manne of Leisure
What did you tap for power for the LOC?
Old Apr 14, 2015 | 11:09 AM
  #250
drdaniel41's Avatar
I grabbed power from the 12v going to the amp. However, while playing with it yesterday, I realized I should just grab power from the remote wire so it's only on when the stereo is on I'll update if my problem continues.
Old May 15, 2015 | 02:17 PM
  #251
Ednica87's Avatar
Hey guys, I plan on swapping out my stock sub and replace it with an aftermarket sub w/ amp but I'm trying to find a diy on how to remove it. I already broke the bose cove trying to remove it from the top, but don't want to f anything else up. It's my project this weekend.
Old May 16, 2015 | 12:16 AM
  #252
You have to remove the rear c-pillar covers, and the rear deck trim to get to the bolts holding it in.
Old May 17, 2015 | 09:35 PM
  #253
Ednica87's Avatar
If this helps my loc device is only using pos & neg wire from stock sub connector and rca's to amp, all other line were snipped from the device. Try splicing the wire to run from there. My car already had everything wired.
Old May 17, 2015 | 09:38 PM
  #254
Ednica87's Avatar
So I tried taking off the bose sub cover and that was a fail. Then I tried cutting a around the edges from the deck to allow sub to fit and that also failed. After having no luck I found a dyi removing rear deck brake light and it's exactly the same everything except chng'ing the sub in light bulbs.
Old May 17, 2015 | 09:49 PM
  #255
Ednica87's Avatar
Ok guys so I went with an 8" jl w3 sub and paired it with th jl 250/1 amp and I do have to say that it's definitely a huge improvement but I have a couple issues.
1. Since there isn't really an enclosure for the sub besides the cover for the trunk the whole deck tends to rattle slightly. I'm thinking of buying some sound proofing to help reduce the rattle, or adding some type of insulation
2. I don't really have a spot to place the amp. I wanted to hide it but now looking in the trunk the really isn't anywhere I could tuck behind any of the trunk covers. May just have to drill it to back of seat. In the trunk of course.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
