How To Install A Sub In A G sedan Using Stock Bose System
Rating: Thread Rating: 3 votes, 5.00 average.
Old Mar 29, 2013 | 01:59 AM
  #211
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by SickFourDoor
fine there. this sucks i am running out of reasons why i got no sound
Well, these headunits are fragile enough as it is, I guess you've got a good excuse to kick it to the curb.
Old Apr 25, 2013 | 08:03 PM
  #212
DyeKid04's Avatar
question: once i follow all the instructions will my back speakers not be working anymore? or will they just not be amp'd thats the only part i am missing,
Old Apr 25, 2013 | 08:39 PM
  #213
MotoCARR's Avatar
G35 Sedan
This install has nothing to do with the back speakers. It's tapping off of the subwoofer wires in the rear deck.
Old Apr 25, 2013 | 09:26 PM
  #214
DyeKid04's Avatar
so the 6x9's woofers will no longer work or is the sub wiring just piggy backing for the signal wires that go to the amp for the woofers?
Old Apr 25, 2013 | 09:41 PM
  #215
Yes, they'll keep working, but it's a waste to have them running with a real woofer.
Old Apr 25, 2013 | 09:50 PM
  #216
MotoCARR's Avatar
G35 Sedan
Plus it sounds like you have a coupe? There's just a single round sub in the back deck. I think there's a coupe write up sticky too that may also help ya.
Like wrathernaut said, it will keep working but it's pointless with any aftermarket sub, so I just unplugged my stock woofer.
Old Apr 25, 2013 | 10:00 PM
  #217
DyeKid04's Avatar
i was thinking about keeping them hooked up just in case, i have my family i can just remove my box quickly and have the space and have the system not sound like total crap ya know?
Old May 4, 2013 | 07:54 AM
  #218
purp35's Avatar
this was alot of help thnx
Old Jun 20, 2013 | 03:10 AM
  #219
specialed138's Avatar
The 03 sedan looks different. Is it still okay to hook up the loc to the black and white wires like in the DIY or should i hook them up somewhere else. sorry i am very new to this and i dont know what the best place would be to hook up an loc. I am using the same loc as in the diy and im hooking it up to a mono amp.
Old Jun 20, 2013 | 07:06 AM
  #220
MotoCARR's Avatar
G35 Sedan
What's different? Post a pic.
Old Jun 20, 2013 | 09:09 AM
  #221
http://www.flickr.com/photos/97771758@N04/9091102865/http://www.flickr.com/photos/97771758@N04/9093322026/http://www.flickr.com/photos/97771758@N04/9093321562/http://www.flickr.com/photos/97771758@N04/9091101051/http://www.flickr.com/photos/97771758@N04/9093320140/
The amp is completely different. It only has one connection. I wasnt sure if in the pictures there were more wires connected to the sub than the black and white, but it didnt look like it. In the 03 sedan theres 6 wires. I know the green wire is still the amp turn on but should i still splice the loc with black and white wires going to the sub?
Old Jun 20, 2013 | 09:19 AM
  #222
MotoCARR's Avatar
G35 Sedan
Yeah the green/white wire is the only wire that needs to be spliced at the factory amp. Are the wire colors different at the plug that goes into the sub? If the colors are the same you should be good to go. But as with all electronics, you should use a multimeter to test and make sure.(basic one can be had for under $10 at like harbor freight.)
Old Jun 20, 2013 | 09:25 AM
  #223
Im sorry. what do you mean are they the same? In the picture it looked as though the only wires connecting to the sub where a black and white one. and what would i test with a multimeter. sorry i am probably asking noob questions right now.
Old Jun 20, 2013 | 09:49 AM
  #224
MotoCARR's Avatar
G35 Sedan
My bad I was looking at the pics wrong. I thought you were showing there were two plugs on the amp.
The green/white wire on the black/dark plug should be your amp turn on(the wire I was referring to to test) and the black and white wires on the brown plug should be the same audio wires. Don't believe the any of the colors changes from 03-04, just the amp looks different.
Old Jun 20, 2013 | 09:52 AM
  #225
thanks i really appreciate it. This is my first time wiring up subs. probably the most ive messed with a car.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
