Help me make my decision
Old Dec 3, 2008 | 01:58 PM
G35zKP's Avatar
Ok, so I've searched and searched, lotsa interesting stuff but I haven't actually seen this question to be asked so.
Situation is, 06 g coupe, no nav, but fully loaded otherwise.
I want to be able to control IPOD from steering wheel, in which case I would either be getting the USA Spec or the Nissan one. Now, thing is, at some point in the not so distant future, I plan on going DD conversion with an Avic Z3. When this happens, and say I already have my car equipped along with either the USA Spec or Nissan ipod controller, will they still work as they did before installing the DD Z3? Or will it lose all functionality in which case I'm basically out $200 because I would then have to hook it up different, to the Z3?
My dilemma is mainly being, I really cant wait to till I get the DD just to be able to use my ipod in the car (and that ****ty radio receiver is out of the question lol), so therefore if I can use the USA Spec or the Nissan connector in the mean while, AND it would still work after the fact, then it is totally worth it. On the other hand, say it does still work but since it is a new HU nothing is going to be displayed on the Z3 screen (which I would prefer) then I would have to swap it out for whatever part I need to make it display on the Z3.
Also, when the time comes that I get the Z3, is it possible that it can be hooked up to the stock bluetooth? (I would imagine it would lose its functionality) Or would I have to buy the separate pioneer bluetooth adapter to work?
Looking to get some advice from people who may have run into similar situations at some point.
Old Dec 3, 2008 | 03:05 PM
MR. WOMO's Avatar
G35zKP,
I don't think it would be usable afterward. I have the USA SPEC PA11-NIS unit and recently removed it during my install of my Pioneer AVIC-F90 unit.
I no longer use the steering wheel controls now as a lot of the unit is voice activated. About the only thing I no longer have is the volume control on the steering wheel, which IS a bummer. But since my iPod now is attached to the head unit, the PAC interface seems like it wouldn't work. Honestly, I never even looked into it - but now that you mention it, I wonder if it could have somehow worked together - oh well!
That said, my unit is for sale if you are interested. I would be willing to part with it (it is in perfect condition by the way - only in my G for less than a year) for $100 if you paid for shipping.
PM if interested, and hopefully someone will be able to answer more fully whether it could work with your setup in the future.
Cheers,
Kev
Old Dec 3, 2008 | 03:36 PM
ttrank's Avatar
Grocery getter
Won't work.
Get a used one for now and re-sell when you go with an aftermarket head unit.
Old Dec 3, 2008 | 04:12 PM
fishhouse's Avatar
i'm not 100% sure where the USA Spec installs. in other words if it has to go in the trunk like the Nissan unit OR if it can just be plugged and installed anywhere up front, behind the dash like the PAC unit that many use. maybe someone with one can chime in on where they have it located.
don't most DD units these days come with iPod connectivity built in? i've never been in the market for one...so not sure but i just assumed that was a feature that most would have now.
if so, i'd just get the cheapest and easiest to install unit now and sell it later (if your new HU has ipod connection) or just reinstall it (if it doesn't and you need to use it with the new HU) - prob the USA Spec.
Old Dec 3, 2008 | 04:36 PM
Slvr G35's Avatar
USA Spec is plugged into the back of the BOSE Audio system.
Old Dec 3, 2008 | 04:43 PM
fishhouse's Avatar
^ that's the one i'd do in your situation then.
Old Dec 3, 2008 | 05:29 PM
G35zKP's Avatar
Thank you all, your help is greatly appreciated . As for the DD having ipod connectivity, yes the Z3 does have it, but I believe you need a separate unit to allow it to work in addition to the Z3 unit itself (one that Pioneer makes) in which case I would assume that steering wheel controls would not work to control the ipod, even if it is displayed through the Z3 HU? If the steering wheel controls do work though in this situation, then that would be ideal for me and I definitely would just get a USA Spec in the mean time until I get the DD unit. Is there anyone who has a pioneer DD HU in their car and they can use steering wheel to control ipod as well?
Old Dec 3, 2008 | 05:46 PM
TroysG's Avatar
steering wheel controls WILL work (probably only track up/down) mode will likely switch sources. but you have to get a steering wheel control interface
Old Dec 3, 2008 | 06:23 PM
G35zKP's Avatar
^ Volume control won't work?
Old Dec 3, 2008 | 07:07 PM
TroysG's Avatar
volume control will work I was referring to the ipod
yosip1115
Forced Induction
Jan 28, 2016 02:51 PM
