Cdt ef-61fg
Old Jan 10, 2009 | 07:33 PM
kaloman's Avatar
Cdt ef-61fg
Wassup everyone,
I just saw this on Woofersetc.com and thought it might be a good deal to jump on. I've heard nothing but good things about CDT speakers and I think it's time to upgrade my Infinity Kappas.
http://www.woofersetc.com/index.cfm?...roduct_ID=4630
I'm pretty sure this will fit depth wise, but are the 1" Zenclosure spacers and stock hole big enough as far as hole diameter? Also, are these components rated for 170W RMS each side or combined?
Aloha!
Old Jan 10, 2009 | 07:38 PM
afmafia's Avatar
170 a side i would get the hd series
Old Jan 11, 2009 | 08:54 AM
kaloman's Avatar
Is the hds worth the price difference? What are the differences between the two?
Old Jan 11, 2009 | 09:49 AM
afmafia's Avatar
yes deff worth the price diff . wooferetc has hd62 for like 230 ish and hd62z for 300. the 62z has better crossovers
Old Jan 12, 2009 | 12:14 AM
TroysG's Avatar
you better put an amp on those speakers if you're going to get them...
Remember it's better to over power a speaker than under power it.
Kappas a good factory replacement speaker but if you're upgrading to a DECENT speaker you need to give them some power
Old Jan 12, 2009 | 04:30 AM
The Stimulation's Avatar
Eh, I'd pass on any CDT set.
As for underpowering vs overpowering, it all depends. Overpowering can lead to mechanical failure whereas underpowering will not. Downfall of underpowering is that you don't get the full potential of the driver.
Old Jan 12, 2009 | 05:26 AM
kaloman's Avatar
Thanks for the input guys. As far as powering them, I was planning on getting a JL 300/2 slash amp because I don't plan on running any speakers in the rear. I'm pretty sure I'll be getting the CDTs but on the border between the on sale EFs and the HDs. Only thing the HDs are over a 100 bucks more and would I really be able to tell the difference in sound quality? Everything will be mounted in the stock speaker locations, which reminds me, are the tweeters going to fit in the stock pod without any modifications?
Thanks again!
Old Jan 12, 2009 | 09:55 AM
TroysG's Avatar
fitting tweeters: it depends on the depth of the tweeter, but in most cases they'll be fine.
if you really have a good ear for acoustics then you'll notice a difference. I noticed a difference going from the Focal Polyglass to the Focal K2s (one step above)
Old Jan 12, 2009 | 09:58 AM
TroysG's Avatar
You're right if you over-power a speaker too much (give it 300 watts when it's rated at 100) you're going to freeze the voice coil or blow the cone.
If you try to make the speaker work too hard (cranking it) by under-powering it you will freeze the voicecoil over time. And you won't get the full potential out of the speaker.
I've seen more cases of blowing speakers because the speaker has been underpowered than over powered.
Old Jan 12, 2009 | 12:12 PM
I guess I can see how that would happen, by being underpowered. Generally you can't actually a speaker by underpowering, but, if you are sending a clipped signal by cranking the gain too much, using bass boost, etc, that itself can destroy the speaker.
To the OP, why don't you look into Image Dynamics. CDT's are known to have plenty of reviews, both positive and negative. Many audiophiles dislike how they sound. I truly suggest going to somewhere they carry CDT's and you have a listen before buying.
Old Jan 12, 2009 | 01:40 PM
TroysG's Avatar
^^^ +1 on listening to speakers before you buy
Old Jan 17, 2009 | 11:53 PM
kaloman's Avatar
Aloha guys/gals,
Well, after many days of reading forum threads and reviews, I've decided to go with the CDT HD-62Z components. The only thing stopping me from ordering them is confirmation that they'll fit within my door panel using the 1" Zenclosure spacers.
Can anyone confirm they will fit with a 1" spacer?
Mahalo!
Old Jan 18, 2009 | 01:37 AM
k67p67's Avatar
I'm a fan of CDT components. I ran a set of HD-62 components in my '06 coupe. I think I used a 0.75" mdf spacer ring. I ran some CDT tweets in the OEM sail panel location but I can't remember if they were from the HD set or my Upstage tweets. They can be a bit bright in that location. A good alternate location would be in the A-pillars firing at the middle of the windshield.
Old Jan 18, 2009 | 09:42 AM
TroysG's Avatar
hey Kaloman I'm pretty sure they're going to fit.
they only have a 2.75" mounting depth, so you should be alright. My focal K2s have a depth of 2 13/16 which is a lil bit deeper than yours and I think I'm running a 3/4" spacer and no issues.
Old Jan 18, 2009 | 11:27 AM
blazeplacid's Avatar
pirce is good only because the mids are the only decent part
that 450 crossover is terrible and the drt 25 tweet is awful
i ran the 480 and its a bit better but you need to step up to atleast the 560
