60k Fluid change???
My '03 G35 sedan has a little over 60k, and are really for the 60k tune up. I just want to know if I should change all the fluids, which included: 5AT Transmission, Differential, Brake, Power Steering, Coolant, and Engine belt.
What do you guys think? Anything I should not change at the moment? Everything in the car works fine. Should I not fix it, if it is not broken? Or go ahead and get everything done?
Oh, any input on all those plastic hoes? When do they need to be changed?
Thanks
Ike
Thanks
Ike
