Stock navigation in non navi G35
Old 06-19-2004, 03:14 PM
ASUG's Avatar
Re: Stock navigation in non navi G35
Is there ne way to get around it, caus i need those vents to work in AZ.
Old 06-19-2004, 03:20 PM
ASUG's Avatar
So there is no way to get the cubby door to close, and to have the A/C work in the back?
Old 06-19-2004, 05:38 PM
mstil35's Avatar
It depends on how long/deep the chassis of the headunit is. I havbe the Kenwood KVT-911 and it wouldn't fit without the modifications. Good luck!
Old 06-19-2004, 08:56 PM
Cruz's Avatar
The rear seat vents aren't that big of a deal...just as long as the front vents aren't affected. Cool, I def. look into this.
XMLM
Old 06-20-2004, 03:55 PM
ASUG's Avatar
They are a HUGE deal when it is 110 degrees out like most of the summer here. I am starting to think about getting the double din instead.
Old 06-21-2004, 12:21 AM
RamboRami's Avatar
G35driver.com Moderator
double-din is the ONLY way to go... think about it, i know its $400 which is costly, but you will always have your stock radio/dash at hand incase you ever wish to sell your car or if you have warranty issues.
Or you can customize your dash, a permanent job, which will run you $200 to $700 (depends on the extensiveness)
So, the choice is obvious.. double-din
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din<P ID="edit"><FONT class="small"><EM>Edited by ramborami on 06/21/04 08:56 AM.</EM></FONT></P>
Old 06-21-2004, 11:50 AM
ASUG's Avatar
I am starting to go towards that now b/c of the A/C problems.
If I do that is there any way to keep the 6CD player indash?
Old 06-21-2004, 11:58 AM
RamboRami's Avatar
nope you wont be able to keep the stock changer installed.
the circuit board and buttons are built-into the face of the stock dashboard. (anti-theft design)
Old 06-22-2004, 05:35 PM
nate1749's Avatar
I don't have the stock navigation, but have a quick question about it. I've read the following on various threads
The stock navigation is motorized
The stock navigation is not motorized
The stock navigation needs to be pushed shut
The stock navigation is spring loaded
As you can see, I'm a bit confused. Exactly how does this thing function? If it's spring loaded, is it smooth?? Sorry for the novice question, I'm just looking into getting the stock holder (~$700) with an aftermarket screen and can't seem to grasp this detail.
Old 06-23-2004, 12:17 PM
RamboRami's Avatar
its spring loaded, not motorized and needs to be pushed-down to be shut. Angle adjustment is very small though, with the screen being that high up im sure you will get tons of glare on a bright sunny day.
press a small button on the top and the unit pops up smoothly. push it down to put it away completely
Old 06-29-2004, 10:42 AM
kamikazeiG35's Avatar
From an convenience perspective, wouldn't going with the Infiniti model be the cleanest and (supposedly) the easiet to do? Since the space is built out for that equipment (as opposed to an aftermarket) And assuming you could get it done elsewhere for less and weren't too worried about no warranty?
Just wondering,
Al
netcbc
Exterior - Body Parts CDN
08-21-2015 09:50 AM
laksjd84
07-24-2015 05:12 PM
vstypicals
07-20-2015 10:55 PM
newbdriver01
07-15-2015 06:10 PM
Quick Reply: Stock navigation in non navi G35
