Which JL audio set up do i go with?
Old 03-05-2009, 08:08 PM
NaiveRapture's Avatar
If I have a Profile California 1000w amp, that puts out 300w RMS at 4ohm and 500w RMS at 2ohm, which ohm subwoofer should I buy? Currently I have a 10" Infinity Reference (4ohm) and am looking to upgrade. I post in this thread specifically because I was considering the W3.
  #32
Old 03-05-2009, 08:50 PM
The Stimulation's Avatar
I'd go with a w3 with that much power
  #33
Old 03-05-2009, 08:52 PM
Right, but what ohm rating? I think they come in 2, 4, and 8... Not sure which would work the best. Right now I have the gain turned almost all the way up, same with the bass boost. Amp barely gets hot though, only if it's been slamming for a couple hours.
  #34
Old 03-06-2009, 12:24 AM
jin22gt's Avatar
you guys think the jl w3 is better than w6? (one 10" for a 4080box )
  #35
Old 03-06-2009, 12:29 AM
What you mean by 2, 4, and 8?
And you may be damaging your equipment. You may be clipping the amp.
  #36
Old 03-06-2009, 12:30 AM
Depends on the amount of power.
  #37
Old 03-06-2009, 12:39 AM
jin22gt's Avatar
JL audio slash 500/1v2
  #38
Old 03-06-2009, 10:39 AM
Tacoman22's Avatar
My current set up is 2 8w3v3s in a ported box powered by a 500/1 and its more than I need and doesnt consume much space about the same as the Zencloure boxes!
  #39
Old 03-06-2009, 11:01 AM
TroysG's Avatar
Jin - W6 would work fine
  #40
Old 03-06-2009, 11:58 AM
Swap for the older 8w6's! Haha. I'd like to find a good deal on oldschool 8w6's but they sell for around 100-150 each still. Would love to a quad 8" setup.
  #41
Old 03-06-2009, 12:16 PM
Tacoman22's Avatar
I was thinking about going with older 8w6's i still might but these w3's are wild in my trunk!!
  #42
Old 03-06-2009, 12:18 PM
2ohms, 4ohms, and 8ohms. The w3's can be purchased with any of them, with the amp I posted above, what ohm rating should I use with a w3?
  #43
Old 03-06-2009, 12:50 PM
TroysG's Avatar
depends on your goal of output vs sound quality, and power/capabilities of your amp(s)
  #44
Old 03-06-2009, 01:17 PM
If going with 2 subs and if they are single voice coil then i'd go with 2 2 ohms or 2 8 ohms, won't make a difference since they will both wire to 4 ohms. If going with 1 sub, then single 4 ohm.
If you go to google and type rockford wiring wizard and click the link for it, you can choose up to 4 subs and different wiring configurations to determine what you can wire the subs to.
  #45
the w6's would rape the w3, both older and newer, hands down, without a problem.
Quick Reply: Which JL audio set up do i go with?
