No audio from Nav after doulbe din install. Help
Old Jun 19, 2004 | 04:08 AM
Zen's Avatar
Zen
Just finished installing an after market Head unit. I followed the double din DIY. Nav works but I no longer have the voice guidence. Everything else works fine. Any one else have this problem and is there a way to fix it.
Old Jun 19, 2004 | 02:16 PM
djrobx's Avatar
Re: No audio from Nav after doulbe din install. Help
The only solution I've seen for this is to add a small dedicated amp and speaker for the navi voice by tapping into the factory wires that were disconnected from the Bose HU.
-- Rob
Old Jun 19, 2004 | 03:04 PM
dave's Avatar
When you are replacing the stereo, there are several connectors you have to deal with. One of them should have been a white 32 pin connector. Wires 32 (blue with white stripe) and 30 (white with black stripe) of that connector are the + and - signals from the NAV. What did you do with those?
You could connect those directly to a small external speaker to get the NAV voice back. But then, you will want to mute your stereo when the NAV is speaking. I don't know how to do that with your head unit, but wire 31 (blue) in the same connector is grounded when the NAV is speaking.
HTH
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Old Jun 24, 2004 | 04:26 AM
Zen's Avatar
Zen
So wires 32 and 31 connect to a dedicated speaker and wire 31 would connect to the Mute wire (brown on the Kenwood DDX7015) on the after market HU. Right?
Old Jun 24, 2004 | 05:05 PM
RamboRami's Avatar
G35driver.com Moderator
Zen, in theory yes, check this thread here:
https://g35driver.com/forums/showfla...sed&sb=5&part=
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
Old Jun 24, 2004 | 05:18 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
yeah..... I don't know how to remedy this problem since I personally don't have nav.
No stock nav coverage, Sirius, XM in Hawaii.
doc
Old Jun 24, 2004 | 11:07 PM
Zen's Avatar
Zen
I will make it work!!! I'm just not looking forward to taking the dash apart again.
Old Jun 24, 2004 | 11:48 PM
RamboRami's Avatar
haha...dont worry, the more you take it apart, the easier it gets, doc and i had a competition....
he took it apart in 5 minutes, i took it apart in 4:59 lol
its VERY easy to do the 5th and 6th time around [img]/w3timages/icons/wink.gif[/img]!
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
MrIP35
Nov 8, 2015 10:47 AM
BfloG35
Oct 16, 2015 05:22 PM
