Trunk release problems on 2003 G Coupe
Old Aug 28, 2009 | 11:38 PM
jschnell's Avatar
Thumbs up Resetting of Valet Button in Glove Compartment Resulted in Fix!
Thanks to all for the postings and threads! I have G35 2007 and the trunk would only release while pressing using the key FOB. Fortunately for me the only thing I had to do was reset the valet button in the glove compartment from On to Off and then to back On again. Thanks for the help, the time and money everyone just saved me with such a simple fix!!
Old Jan 20, 2010 | 04:10 PM
civic4982's Avatar
greatness! I'm gonna go chyeck mine out when it stops raining.
Old Mar 31, 2010 | 03:13 PM
Integi2a00's Avatar
just fixed my trunk because of this thread good stuff..... paranoid i was going to pay nissan $88 to just look at it.
Old Mar 31, 2010 | 11:08 PM
civic4982's Avatar
yup mine had the same problem. just reconnected the wire and it worked out fine.
Old Jul 1, 2010 | 12:22 AM
SxyG35_408's Avatar
it worked, pulled the wire harness out and open it up, split wires. re connected, bingo!
Old Apr 15, 2015 | 09:17 PM
DanAmundsen's Avatar
Originally Posted by STILLENRedline
you are lucky I happened to be reading your thread. The problem is most likely to be the wire inside your truck. There is a rubber tube that encloses the spoiler and trunk wires and connect from the body of the car to the truck lid. I'm 99% sure that some wires in there are broken. Any 2003/04 will go through this. splice back the wires and you will be fine.
@STILLENRedline - Thanks! That was the fix for me! You saved me a few hours and cigarettes!
Old Apr 15, 2015 | 10:51 PM
Urbanengineer's Avatar
All 03-07 coupes and 03-06 Sedans have this issue.
Old Apr 21, 2015 | 10:26 PM
MacG35's Avatar
Brake activates trunk latch
Help! 2004 G35 Coupe I have trunk switch issues too and was going to try the wiring check but two days ago every time I step on brake the truck latch activates. What the heck is that all about?
Old Apr 22, 2015 | 02:29 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The broken wrap on the wires is causing the brake light wire to contact the trunk latch wire.
Follow the guidance in this thread to expose the wires and fix them. I'd recommend soldering in replacement wire and use some good heatshrink wrap, but you can probably get by just wrapping the section of wires with electrical tape if you want to half-*** it.
Old May 28, 2015 | 03:39 PM
TKrygiel's Avatar
Which fuse controls the trunk? I looked down by the pedals and behind the battery but I didn't see a label for one.
Thank you,
TWASkyliner
Feb 8, 2020 08:00 PM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
realtalk21
Jul 20, 2015 09:07 AM
attarday
Jul 15, 2015 04:03 PM
