Audio Upgrade - 07 Sedan
Old Feb 26, 2009 | 03:49 PM
Pdubz's Avatar
So i have a 07 g35x with premium bose.. my friend is givin me a pair of 12inch audiobahn subs and amp.. hes gonna help me install.. but just need some answers to some questions..
like what else do i need besides cables.. i heard a friend say i need an rca converter?
anyone have any write ups on installing subs or removing trim??
thanks!
Old Feb 26, 2009 | 04:07 PM
mishmosh's Avatar
There is a line level that you can simply tap from the bose amp module to the power bose amp in back--no line converter needed. which one is listed in the factory service manual. Adding a sub makes a huge difference to the Bose system.
Old Feb 26, 2009 | 04:14 PM
suby01's Avatar
dude let me know how it goes. im thinking of adding a infinity basslink self powered 10 inch sub.
Old Feb 26, 2009 | 04:22 PM
Pdubz's Avatar
no disrespect.. i value ur respons.. but honestly.. i have no idea what u just said..
im not trying to replace anything. i want to keep my oem speakers including the oem sub in the back.. i can just hook up the 2 subs and another amp TO the oem headunit. is that possible??
so i DONT need a converter??
Old Feb 26, 2009 | 04:28 PM
Hi-TechG35's Avatar
PDubz here's what you will need
1.4 gauge power wire
2.4 gauge ground wire
3.20 gauge remote wire
4.fuse holder and some 60-80amp fuses
Also PM Iron-Mike becuase he has a full plug and play harness that will save you the hassle of cuttin into your OEM harness.
Old Feb 26, 2009 | 04:52 PM
Pdubz's Avatar
thanks hightech. my friends tryin to help me install so he needs some info.. so im just forwarding questions..
does my oem headunit have rca outputs??
Old Feb 27, 2009 | 03:41 PM
hrp783's Avatar
i had a pro install my JLw7 and JL amp.
they took out the stock bose sub, for airflow..
anyone want to buy a stock bose sub? PM me
Old Feb 27, 2009 | 03:45 PM
Hi-TechG35's Avatar
The OEM doesn't have outputs. If you need a hand PM me. I'll give you my cell and try and walk you through it.
Old Feb 27, 2009 | 04:32 PM
TroysG's Avatar
Sticky on adding a sub to Bose system. not exactly for your car but gives you a clear idea of what to do
https://g35driver.com/forums/audio-v...se-system.html
Old Feb 27, 2009 | 04:42 PM
Pdubz's Avatar
ok so i need a line out converter correct?? any suggestions in brand?? or where to buy??
Old Feb 27, 2009 | 05:03 PM
TroysG's Avatar
there's a wide range. since you're just doing subs you can use a fairly cheap one. the money would wasted on the higher end guys. I don't think you'd have to spend any more than 50 bucks on one - still at 50 you're going to get a pretty decent one
mjfenix
Aug 17, 2017 05:49 AM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
Cacoepy
Aug 3, 2015 01:09 PM
