Need help to make false floor and sub box
Old Mar 6, 2009 | 04:18 AM
T.Y.M1210's Avatar
I been searching through the forum but i can't find the help i need, becuz i want to make a false floor and a sub box but idk what materials i need and how much space to make for it, my system is 4 10" and 2 amps. thank you.
Old Mar 6, 2009 | 10:58 AM
TroysG's Avatar
wow big system to be doing by yourself without some pro guidance and without the clue to start it...
well I'll help ya out with some materials you MAY need
3/4" MDF - depending on how you plan on setting this up you may need anywhere from a half sheet (4x4) to a full sheet (8x4)
Fibreglass resin
likely 1/2" chop matt - strong but still easy to work with
If you're trying to make a molded or formed enclosure for the subs or amps you'll want some polar fleece.
Paint/carpet/fabric
Bondo - if you're painting your enclosure or trying to make it show worthy - to smooth out the imperfections.
Since I dunno what you have pictured in your head that's as far as I can go to help you.
Old Mar 6, 2009 | 02:00 PM
T.Y.M1210's Avatar
Thank you for your help, i need to start looking for some MDF, oh as for my set up i want to put the amp where my spare tire is at and the sub around it, but idk if i sud replace my spare for the amp. n feel free to add anything else, CUZ I NO I'LL NEED IT.
Old Mar 6, 2009 | 02:59 PM
TroysG's Avatar
haha well what you're looking at doing isn't going to easy. especially if you have a coupe.
what I'd probably do is still put the amp in the spare tire well (especially if you have AAA or CAA) cut out a window to display the amp (but less than the size of the amp) notch the top edge with a rectangular router bit and get a piece of plexi or lexan to protect the amp.
then the subs....
first off I'd probably cut the top and bottom to shape you want (and will fit). then take a piece of 1/8" board (can be anything really). and have that as your front face (so that it curves around your amp evenly) then build boxes that will suit the sub and fit in the allotted area. But you can build the boxes more like a skeleton without the top and bottom b/c you and pretty much slide it into the design.
If you want to be able to remove it you can make it 2 pieces by cutting it in half.
I'll try to draw something out, and scan it to give you a better idea of what I mean.
Old Mar 7, 2009 | 01:17 AM
T.Y.M1210's Avatar
HAHA, my car is indeed a coupe OB coupe, N yes (AAA) all the way, haha, i went to LOWES to get some MDF, today and some other stuff, n remove my spare tire, but really appreciate for the advices, Can't wait to c what u drew out really look for it to it
Old Mar 7, 2009 | 08:07 AM
TroysG's Avatar
sorry man completely forgot. I'll do it now.
Old Mar 7, 2009 | 08:28 AM
NaiveRapture's Avatar
I'm interested to see where this goes!
Old Mar 7, 2009 | 11:02 AM
TroysG's Avatar
it's nothing overly exciting. I've just adapted it so that no fibreglass is being used.
Old Mar 9, 2009 | 04:33 AM
T.Y.M1210's Avatar
Me too man, hope it will turn out good, u no come from a guy that is not pro with this stuff, but let just wait n c, I'll post some picture when i have the stuff in place.
Old Mar 9, 2009 | 04:35 AM
T.Y.M1210's Avatar
PM send and thank man for taking the time and help a G member out. (this is the reason why i love this forum)
Old Mar 10, 2009 | 04:35 AM
T.Y.M1210's Avatar
The drawing made it more clear for me thanks man (quick artist), but there something i want to ask if the amp go in the spare tire, how do i get it to stay in place, do i need to make something or build like a rack for it to sit on? N hope u don't mind me asking alot of these stuff man.
Old Mar 10, 2009 | 07:16 AM
TroysG's Avatar
no worries man
just take a piece of cardboard (fairly large piece) and take an exacto knife and cut a template. so that it fits snug in the spare tire well, then use a piece of mdf and you're good to go as long as it's a tight fit. once I find my camera I'll take a picture of my setup for ya.
got a ton of car goodies, got no home goodies haha
Old Mar 14, 2009 | 04:02 AM
T.Y.M1210's Avatar
Thanks for the advice man, i been up and down trying to put things together, (some reason i blew out one of my sub), but thanks though, i'll try to post some pics up when i get a chance (when i get another sub). OH how your LED clearance strip going?
Old Mar 14, 2009 | 02:51 PM
str8dum1's Avatar
without using anything besides lo profile subs, your false floor is going to be SOOO high. i'm using some Illusion neo subs at only 3" deep and the floor is still about 1" higher than the normal trunk when you fold the rear seat down. And thats with only ~ 1.5 cubes of airspace. You have to take into account the grill thickness as well in the overall floor height so you dont have to worry about crushing the cones.
good luck. measure twice, cut once
chinee
Jun 10, 2024 07:48 PM
11bEMT
May 27, 2022 03:13 PM
DRG35R
Jul 31, 2015 10:23 AM
