Hollow sound, speakers in a tunnel?
Location: Los Angeles, National Socialist Democratic Republic of Facistfornia
on
Don't be hatin on the IDs. They're ID OEM mids, not exactly CX62. An evolution that didn't hit the mainstream. I doubted that 25w would be enough, but I trusted the pros and it's really quite good. It'll do until the amp gets replaced when I go 3-way fronts someday
Only broke in the mids, didn't run the tweets until they were in the car. My receiver outputs 4 or 8 ohm selectable so no worries there. Tweets sound nice, real bright and airy. Bit hard to tame without an eq, but we'll fix that. The tweets are connected to the rear channel of the 500/5 bandpassed. Only 25w, but plenty power. I have a few other RCA cables laying around. I'll see if possibly it's the cables. They're multishielded, lots thicker than the twisted pair, but who knows.
Why did you bandpass the tweeters? Where did you mount them? It almost sounds like it could be a phase problem. You should try swapping the + and neg of one and possibly both of the tweeters. If they are out of phase it could cause a hole in the freq response. They may both be out of phase from the mids and trying it different ways should be able to tell you. It is odd that it would go away and then come back. That sounds like an equipment issue if it persists.
Appreciate the feedback. The Seas are much better now. They're just HP at 2.6Khz now and are much more laid back. I have them in the sails, but angled in quite a bit. Suckers had to be seriously cut down to fit in there. Definitely wired in phase. Stereo is actually sounding a ton better over the last week
DEMoLITIoN
Audio/Video/Electronics
04-20-2016 06:57 PM
