07 G Coupe BOSE-Replace Stock Speakers & Amp
Old Mar 24, 2009 | 05:29 PM
cpezie's Avatar
I looked through the previous threads but could not locate any where someone wanted to add a aftermarket amp without adding a sub.
So here's what I'd like to do. I want to replace my stock speakers (all 8 of them 2ohm) and add an aftermarket amp. I already have an old Sony CX-6000 (6ch) amp which has the following:
full front speaker mode which I will connect my component spkrs to
full rear spkr mode which i will connect a set of 6 1/2's
sub channel which i will connect a set of 6x9's (I'd love to retro fit a set of 8' subs in the rear deck )
All speakers will be 2ohm as I understand it that's what the Bose setup calls for.
Here's what I'm thinking I need but I want to ensure that my thought process is correct.
I need the AudioControl LC6i and place it between the stock amp and aftermarket amp.
Question: should i splice the stock wiring before or after the bose amp?
I will splice the speaker wire and run them to the LC6i.
Did I miss anything?
Sorry for the long post and if this has truly been covered previously please point me in the right direction.
mjfenix
Aug 17, 2017 05:49 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
kd03g99
Jul 30, 2015 11:24 AM
Thunderaan
Jul 22, 2015 07:40 PM
