Speaker problem
Old Apr 10, 2009 | 07:26 PM
vipers's Avatar
Originally Posted by Habsfan
For what its worth, I am having the same problem. I'll be watching this thread closely in the hope someone comes up with a fix.
If I knew more about wiring and things like that I would just pull out the radio and maybe find something wrong, but I've never been good with electrical issues. I'm strictly mechanical
Anyhow, like I said earlier I will be ordering a new (or slightly used) OEM radio and see what happens. From what I can tell that's the only "fix."
Old May 19, 2009 | 02:40 PM
Rob21r's Avatar
I have been having the same problem with my passanger side also. It has to be the head unit because i have bypassed the factory amp and am running a high's and bass amp. I have checked all connections for the amps and speakerwires everwhere except for the headunit. I would really hate to have to replace the headunit because that is gonna be a pretty penny.
Old Jun 29, 2009 | 09:22 PM
jlacroix21's Avatar
im having the same issue, anyone fix this issue? my front right is the only speaker working with the CD player... with the radio it is the only one NOT working? wtf
Old Jul 6, 2009 | 12:06 PM
partyman66's Avatar
Same problem here.. my '04 6MT G35 Coupe just started doing this like 2 days ago. It's really annoying.
I may rip the head unit out and take it apart to see if I can figure out a fix for it if it pisses me off enough.... which it probably will, since I listen almost exclusively to CD's in my car.
Old Aug 15, 2009 | 07:34 PM
jmgjj's Avatar
solution?
anyone had luck to fix this fxxxing problem?
I have the same issue for quiet a while -- left front speaker in and out when playing CDs, never tried to use my fist to hit it though....
I looked around this forum and found this, probably a solution
http://www.shiftice.com/Maxima_02-03...dio_repair.pdf
I may try this when it is cooler, too hot outside now.....
if anyone try this method and fix the problem, please keep us updated, thanks a lot.
Old Aug 17, 2009 | 12:35 AM
partyman66's Avatar
I'm planning on taking my head unit apart in a month or 2 once it's cooler outside and less buggy out there. I wasn't aware that someone had posted something like this which tells you how to fix it. I don't like the half-plugged-in solution though, so if I do this I'll probably try to find a more permanent solution.
Old Sep 5, 2009 | 12:59 PM
johhnyex@yahoo.'s Avatar
wow i just joined this forum to try to find help regarding this issue i guess i'm not the only one! it sucks and it is very very annoying because i hate listening to the radio!!
Old Sep 5, 2009 | 04:12 PM
dsmbill's Avatar
yup i got the same problem. if i hit the side of the center console it fixes it for a lil while.
Old Sep 6, 2009 | 08:29 AM
TroysG's Avatar
this thread likely isn't going to help anything... if you do a search, someone has found a guy that can fix them. I can't remember the name of the thread. but in the thread I think it said something about radio md or something like that
Old Sep 7, 2009 | 02:26 PM
stoofpilot's Avatar
CD Speaker Problem-Drivers Side
Same problem-driver side speaker works fine with radio-not with CD. Passenger side works fine. Did anyone take it to a good auto audio shop to have them work on it?? I looked at the Maxima link but that is way over my head.
Any other suggestions other than buying a new CD unit.
Thanks
Old Sep 12, 2009 | 11:59 PM
STAGGERD SEDAN's Avatar
hey guys if any body can help im having a cracklin distorsion sound comin from my unit which is the standard unit,it jus started happening while i was normally turnin on my car.any advise would be greatly appreciated,im ready to jus upgrade everything.
Old Sep 13, 2009 | 12:02 AM
the cd plays ,but with distorsion and ther is no sound coming out at all when i switch to the radio,no music nothing
Old Sep 13, 2009 | 11:32 PM
johhnyex's Avatar
the new unit from a dealer is $700?? i would really like to fix this only because i don't want to have to mess with the interior look, but it seems i may have to just go and buy an aftermarket stereo
Old Sep 20, 2009 | 02:15 AM
gck's Avatar
gck
wow $700. here in FL they are charging me $499 plus labor.
Old Sep 20, 2009 | 08:26 PM
  #30
vipers's Avatar
Wow, nice to see my thread went so far. Well I haven't found a fix for the CD player but I have for the tape deck. I was using a really crappy tape deck MP3 converter, and I just bought a new one. Knock on wood...it works perfect!
I suppose the only fix for the entire thing is to buy a used unit...if you buy a new one you need your head examined.
