Speaker problem
Old Mar 27, 2009 | 01:10 AM
vipers's Avatar
Speaker problem
I've been noticing that my driver side speaker isn't playing when I use my tape or CD deck...however it plays just fine with the radio. Could this be a connection problem? Would it be to the speaker or into the actual stereo? I'm assuming it's not a problem with the speaker cause it really does play totally normal when I use the radio. I'd appreciate any advice.
Matt
Old Mar 27, 2009 | 01:38 AM
RyanFow's Avatar
I have the same problem. Its a pain is the A**. I think the head units done?
Old Mar 27, 2009 | 06:39 PM
vipers's Avatar
I'm thinking it's a connection problem with the unit cause it doesn't make sense that my audio is fine when I play the radio.
Old Mar 28, 2009 | 09:29 PM
mnrg35's Avatar
i am having the f****ing same prob. and i agree it is a pain in the a** specially when you have a new cd you want to listen too
Old Mar 29, 2009 | 11:50 AM
TroysG's Avatar
hey guys the more you search the more answers you'll find... alot of guys have been just tapping the side of the radio to remedy that. basically it's a loose solder point inside the radio. if you still have warranty get it fixed for free, if not time for a new deck.
Old Mar 30, 2009 | 02:49 AM
mnrg35's Avatar
Is there a way that I can fix it myself??
Old Mar 30, 2009 | 11:05 AM
vipers's Avatar
One thing I forgot to mention that used to work for me is just slamming on the brakes. I guess it kind of moved something from the pressure and it would always work...but it doesn't anymore. Again my original thought was that it's a loose wire or something connecting to the speaker or the unit, but perhaps I just need to replace the unit itself.
Old Mar 30, 2009 | 11:25 AM
mnrg35's Avatar
That would work for me sometimes. Not it seem it is getting worst day by day
Old Mar 30, 2009 | 12:54 PM
sleev-les's Avatar
Your problem is something inside the radio. A connection would go in and out when you hit bumps in the road or shut the door.
Old Apr 2, 2009 | 10:31 AM
vipers's Avatar
So do you think I need a new one or there's maybe a wire or something that's the problem?
Old Apr 2, 2009 | 01:58 PM
sleev-les's Avatar
You will need a new radio. Do you have the Bose system, or the standard system? If its standard the only fix is replacing the radio. If it is Bose, it could actually be a problem at the amp or the stereo. Either way, in the bose system, you would have to replace the stereo and possibly bypass the bose amps.
Old Apr 3, 2009 | 01:25 AM
vipers's Avatar
Yeah I have Bose...I'm gonna replace the stereo and see what happens.
Old Apr 6, 2009 | 07:52 PM
g_rated87's Avatar
im having the same BS problem!!! Any luck???
Old Apr 7, 2009 | 02:53 PM
vipers's Avatar
Not yet...it's such a strange glitch. I'm going to either look for a used one in the marketplace or a buy a new radio. I have to listen to music when I drive.
Old Apr 10, 2009 | 05:06 PM
Habsfan's Avatar
For what its worth, I am having the same problem. I'll be watching this thread closely in the hope someone comes up with a fix.
