MORE COUPE BOX PICS FROM 4080
Jul 10, 2004 | 04:46 PM
FIRST OF ALL IF YOU HAVE ANY QUESTIONS ABOUT THE SPECS PLEASE REFER TO THE POST "FINAL COUPE BOX PICS." MANY OF YOU HAVE REQUESTED PICS OF THE BOX INSTALLED WITH THE CARGO NET. WELL HERE THEY ARE. I ALSO INCLUDED SOME PICS OF THE BACK, TERMINALS, AND GRILL SHOTS.
Reply 0
Jul 10, 2004 | 04:50 PM
Re: MORE COUPE BOX PICS FROM 4080
THIS PIC SHOW THE MOUNTING BRACKET. THE BRACKET IS SECURED TO THE PINCH MOLDING AROUND THE EDGE OF THE TRUNK BY THE RUBBER GASKET. TO INSTALL JUST PULL THE GASKET UP, SLIDE THE BOX IN PLACE, AND PUSH THE GASKET DOWN. MUCH BETTER THAN SCREWING YOUR BOX DOWN TO THE FLOOR OR NOT SECURING IT AT ALL.
Reply 0
Jul 10, 2004 | 04:51 PM
THIS ALLOWS YOU TO PULL THE BOX OUT WITHOUT ANY TOOLS. VERY QUICK AND SIMPLE.
Reply 0
Jul 10, 2004 | 04:53 PM
ONCE THE GASKET IS PUSHED BACK DOWN YOU DO NOT SEE THE BRUSHED ALUMINUM BRACKET.
Reply 0
Jul 10, 2004 | 04:56 PM
THIS IS A SHOT OF THE GOLD PLATED WIRE TERMINALS. THESE TERMINALS ARE MUCH BETTER THAN THE PLASTIC TERMINAL PUCK I WAS GOING TO USE. THE TERMINALS GO THROUGH THE BOX SO THE WOOFER CAN BE WIRED ON THE INSIDE. EACH TERMINAL IS MARKED WITH A BLACK OR RED BAND. THIS ALLOWS YOU TO TAKE THE BOX IN AND OUT VERY QUICKLY WITH OUT MAKING MISTAKES ON POLARITY.
Reply 0
Jul 10, 2004 | 04:58 PM
THE BOX CAN BE USED WITH THE CARGO NET. SMALL NOTCHES IN THE BACK OF THE BOX ALLOW YOU TO INSTALL YOUR CARGO NET AND SLIDE THE BOX IN PLACE.
Reply 0
Jul 10, 2004 | 05:01 PM
THIS PIC SHOWS THE NOTCHES THAT ALLOW FOR CLEARANCE OVER THE CARGO NET LOOPS AND HOOKS
Reply 0
Jul 10, 2004 | 05:03 PM
A QUESTION I HAVE YET TO HERE IS "HOW DO I GET THE GRILL OUT?" A SMALL INDENTION IN THE BOX WAS MADE SO YOU CAN GRAB THE BOTTOM OF THE GRILL TO PULL IT OUT. YOU CAN NOT SEE THE INDENTION BECAUSE IT IS ON THE BOTTOM OF THE BOX. NO TOOLS A REQUIRED TO PULL THE GRILL OUT. VERY TRICKY!
Reply 0
Jul 10, 2004 | 05:56 PM
4080, your team has defintely thought this box through. Very nice work. I can't imagine the JL Stealthbox being any higher quality.
2003 G35c/5AT/BS-Graphite/Prem/Aero/Splash/NISMO sway bars/JWT Popcharger/Z-Tube/ValentineOne
Reply 0
Jul 10, 2004 | 06:54 PM
THANKS FOR THE SUPPORT KROAMS! COMMENTS LIKE YOURS MAKES THE HARD WORK WORTH IT.
Reply 0
Jul 11, 2004 | 02:11 AM
soooooooo are you sellign those and if so how much!?!?
Reply 0
Jul 11, 2004 | 02:18 AM
Hey 4080.. show pics of where you installed your amp
Reply 0
Jul 11, 2004 | 02:38 AM
I am going to buy one of these pretty soon. The amp location is my only concern (having nothing to do with the box) but I don't want to lose my trunk pass-through.
Reply 0
Jul 11, 2004 | 11:37 AM
I AM NOT ALLOWED TO POST PRICES. PLEASE PM ME FOR PRICES.
Reply 0
Jul 11, 2004 | 09:48 PM
I FORGOT ONE FEATURE. NOTICE ON THE BACK OF THE ENCLOSURE THERE ARE RIDGES. THESE RIDGES ARE PUT INTO THE MOULDE TO INCREASE STRENGTH. IF THE ENCLOSURE WAS JUST FLAT ON THE BACK IT WOULD NOT BE RIGID. ANY BEND OR REVEAL IN THE FIBERGLASS INCREASES STRENGTH. HERE IS ANOTHER PIC SHOWING THE RIDGES.
Reply 0
