BOSE AMP turns on after Volume is at 20.
Old May 17, 2009 | 05:07 PM
avion's Avatar
My 05 G35 came with the BOSE system. I notice now the factory Amp will only turn on if you bring the Volume to 20. Then you can back the Volume and the Amp will stay on. This happens whether or not the car has started or is in motion or at any speed. Is there a hidden setting I have missed or is the system not working correctly?[PHP]
Old May 17, 2009 | 05:10 PM
Beebo's Avatar
Mine does the same, well i just get more bass
Old May 17, 2009 | 05:28 PM
avion's Avatar
With the Aftermarket Speakers I have installed, the Bose system sounds great as long as the Amp is On... I just wish the Amp would be On at all Volumes...I just thought this a radio setting selection or this a software design problem by Bose?
Old May 17, 2009 | 05:35 PM
gtrefever's Avatar
hmmm, i never actually paid attention ill have to check this out hhaah and actually try to notice.
Old May 18, 2009 | 09:56 PM
madmike1029's Avatar
I never noticed this as well. How do you tell the difference, is it noticeable?
Old May 19, 2009 | 08:00 AM
VandyZ's Avatar
is there an easy way to tell if the amp is on?
Old May 19, 2009 | 11:58 AM
MidnightG35X's Avatar
So you have absolutely no output until you put the radio above volume 20? There is an amp turn on wire that is active as soon as the ignition is turned on. It is a green with white stripe wire on my 04. Have you done any other electrical mods besides new speakers?
Old May 19, 2009 | 12:12 PM
nsyr's Avatar
On mine the Bass and Treble reset everytime the radio is turned off, regardless if the ignition is turned off or not. I either have to bring it up to 20 or reset both.
Old May 19, 2009 | 12:30 PM
OBG3506's Avatar
on my 06 i havent noticed any of this!
Old May 19, 2009 | 04:38 PM
DougJones's Avatar
I haven't noticed the amp turn on issue. But, like nsyr stated, my bass and treble levels reset to flat each time the radio is switched off and back on. Visually, the settings remain the same, but you can hear the difference. I have to bring either of the levels back to flat manually and back up to my prior setting in order for the sound to correct itself.
Clear as mud, I'm sure
Old May 27, 2009 | 06:31 PM
avion's Avatar
BOSE Amp turns on after Volume reaches 20
The other settings work good. They stay in memory after you turn off the radio or car. The AMP seems it needs a trigger level of 20 before turning on.
Sort of works the same way as a HOME Theater Auto switching Amplifier Sub.There is a big difference when it turns on. Volume increases, Dynamic response is greatly improved. Besides replacing the stock speakers, nothing has been touched. It would be a good system if the Amp would be on without having to increase to 20 before lowering it again.
Old Aug 9, 2009 | 04:14 AM
Hooryde2's Avatar
I've noticed that I have to turn my volume up to 20 to get much treble output. Otherwise it sounds really flat. Maybe it's doing the same thing as the other 2. I have an 05 Sedan. Really thought the system sounded like crap until I figured it out. Not it's bearable until I decide to tear it apart and put in my old stuff.
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
JoeMac
Sep 28, 2015 12:28 AM
mattdg35
Sep 14, 2015 11:28 AM
NJ6MT
Sep 10, 2015 08:40 AM
pasjr1972
Sep 1, 2015 10:17 PM
