Subs get cut off when turned up?
Old May 21, 2009 | 04:31 PM
tlu's Avatar
tlu
I have a JL Audio 500/1v1 and a JL Audio 12w6v2. with stock bose HU.
The problem just started today... when ever i turn my volume up to 14+ the sub just turns off or something or stops working as soon as the bass hit. It turns back on after i restart the car but turns off again when i turn it up. What could be the problem?
this is on a 2006 coupe.
Old May 22, 2009 | 12:17 AM
BXG35x's Avatar
does the amp turn off or go into protection mode? it could be clipping issue
Old May 22, 2009 | 12:49 AM
Vrod-Mike's Avatar
This would be my guess as well. Check to see what the amp is doing and then let us know.
Old May 22, 2009 | 10:08 AM
blazeplacid's Avatar
where are your gains set?
are you using a line out put converter?
Old May 22, 2009 | 04:58 PM
tlu's Avatar
tlu
Yeah im using a Hi-Low converter. The sub doesnt even feel as strong anymore.
And ill check what the amp is doing later. And get thes gains etc...
Could it be that the sub blew or something? thats why it is acting like this?
Old May 24, 2009 | 07:34 PM
tlu's Avatar
tlu
bump
Old May 25, 2009 | 05:05 PM
nebbie81's Avatar
It sounds like it could be a problem with the amp. When the sound cuts off, do any lights turn on on the amp? If you have a multimeter, use it to check voltage before and after the fuse, and use it to check how many ohms the sub is wired up to. How is the speaker wired up (series or parallel)?
Old May 25, 2009 | 07:27 PM
tlu's Avatar
tlu
after the sub stops playing the amp is still on. i think its wired to 2 ohms or 4? whatever it is factory wired to. i just took the sub out the box brand new, both voice coils are hooked up, and just put it in a box. and im not sure which way the speaker is wired up as series or parallel? how do i tell
Old May 25, 2009 | 11:55 PM
tlu's Avatar
tlu
I just did it again today, the amp stays on green light? But when the sub turned off i saw that my interior lights, the head unit etc got dimmed.
Old May 26, 2009 | 01:09 AM
blues's Avatar
check your battery..
Old May 26, 2009 | 12:40 PM
kentonio's Avatar
Check to make sure your amp is grounded properly.
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
Thebaws11
Jul 2, 2021 11:36 AM
jilljann1
Jul 21, 2020 08:12 AM
JustinMKN1
Sep 18, 2015 03:40 PM
mattdg35
Sep 14, 2015 11:28 AM
