CEL after installing amp and sub
Old May 30, 2009 | 11:50 PM
VicariousVision's Avatar
I just installed a JL amp with a sub this afternoon (for reference, I have an 05 coupe with Bose). I didn't have any other stereo work before this. After finishing, the whole setup works, but I now have a CEL. Can anyone suggest what might cause this? Do I simply need to just do an ECU reset?
Thanks.
Old May 30, 2009 | 11:51 PM
Invalid_User's Avatar
Take it to autozone and see what code comes up.
Might just be your CATS
Old May 30, 2009 | 11:52 PM
I have stock cats, so I highly doubt that's the cause...
Old May 30, 2009 | 11:56 PM
^Even stock ones will throw one.
Old May 30, 2009 | 11:57 PM
maybe...but if there is an issue with my cats, then why wasn't the CEL on before i installed the amp/sub?
Old May 31, 2009 | 12:01 AM
maybe just coincidence
But you will only know when you check the code
Old May 31, 2009 | 12:24 AM
TroysG's Avatar
are you still using the factory deck? if so where did you get your accessory power from?
Old May 31, 2009 | 12:26 AM
yes, i kept the bose head unit. i am running the power from the positive terminal on the battery. under the red cover, there were two bolts, one with something already bolted on, and another directly next to it with nothing there. i bolted my power cable onto that post and held it down with a 12mm nut that i got from autozone. should i have tapped the battery at another point?
Old May 31, 2009 | 10:38 AM
blazeplacid's Avatar
go get the code checked, free at autozone
probably nothing
did you disconnect the battery while installing?
Old May 31, 2009 | 11:55 AM
i'll go up to autozone today and see what the deal is.
yes, i disconnected the negative during the entire install. i reconnected it once or twice so that i could move the seats back and forth, but for the most part the battery was disconnected. would the place that i mounted the power cable make a difference? i didn't mount it directly to the positive post, i mounted it further down below the second red plastic shield cover to an unoccupied bolt....
Old May 31, 2009 | 04:35 PM
ok, i believe i have this resolved, but just to follow up in case anyone else has this issue:
i went to autozone and i was throwing code P1065 (power supply circuit - back-up ram malfunction). this seemed to confirm my theory that i had mounted the power cable at an insufficient point. for clarification, this is where i mounted it to begin with:
i thought that this might have been a bad idea, so i went home after my enlightening experience at autozone and moved the power cable like so:
i am no longer throwing a CEL so i can only assume this was the issue. i guess the first point was just too far away from the positive post at any rate, i'm sure i'm the only idiot who has ever made this mistake, but i figured i would follow up just in case. thanks to everyone for their advice and input!
Old May 31, 2009 | 09:46 PM
may have been drawing to much current from a source that needed it
thats the way I have my amp wire into the battery
Old Jun 1, 2009 | 11:03 AM
MidnightG35X's Avatar
I had the same thing when I was running new speaker wire. If you disconnect certain harnesses hooked up to the ECM, it will lose its memory (even with the negative cable disconnected) and throw that code. I just cleared it and it has not returned since.
The harness I disconnected was down in the passenger kick panel.
Old Jun 2, 2009 | 08:37 PM
i really don't know what the deal was, but i didn't connect any harnesses in the kick panel up front - just the harness going to the stock bose amp in the trunk. regardless, it obviously had something to do with the power cable. thank god relocating the cable fixed it...i was going to be really pissed if it didn't. oh well...all's well that ends well, right?
hdmark
Apr 29, 2019 04:31 PM
zoop425
Mar 29, 2016 05:51 PM
broke_as_ajoke
Nov 6, 2015 11:49 PM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
