Urgent!! my G Coupe 's alarm screaming w/o control!!!
Old Jun 1, 2009 | 10:46 PM
riflydon's Avatar
i went back home with my G coupe 30 minutes ago
I locked the door by my keyless entry
When i was turning on my PC, my car's alarm scream
and i go down to see wut happen, nth happen
then i press to unlocked button, it stopped
After 5 minutes, it screamed again
I press the unlocked button again, it stopped
AFTER 5 MINUTES, it SCREAMED AGAIN!!!!!!!!!!!
I PRESS THE SAME BUTTON
NOW my car stopped screaming, but wut's happen to my car!!??
I dun want my G-Coupe suddenly screaming w/o control in the morning at 2AM... i got totally fxxked up...
Old Jun 1, 2009 | 10:47 PM
eljoker's Avatar
is it an aftermarket alarm?
Old Jun 1, 2009 | 11:47 PM
riflydon's Avatar
nono, it's stock one, 04 G Coupe
Old Jun 1, 2009 | 11:50 PM
eljoker's Avatar
thats wierd, you sure its not just someone f'ing with you?
Old Jun 1, 2009 | 11:53 PM
riflydon's Avatar
of coz not, coz i was standing there to wait 4 it , to scream another time.
It just screaming un-controlable. I am planning to bring it to Stealership, Do you guys noe how much to fix those ****s?
Old Jun 1, 2009 | 11:56 PM
eljoker's Avatar
idk never heard of the problem i say disconnect the battery and hope no one f's with you untill you get it fixed
Old Jun 2, 2009 | 12:00 AM
riflydon's Avatar
do you think the alarm system is rely on the car's main battary? or it does have it's own/separate battary?
eljoker's Avatar
its on the main, stock ones usally are
best of luck im out for the night
Old Jun 2, 2009 | 01:20 AM
Dablakbradpitt's Avatar
its the battery. Mines was dying so the alarm started screaming like it was being raped
Old Jun 2, 2009 | 01:44 AM
partyman66's Avatar
Are you sure you weren't just crushing the keyfob in your pocket with your body weight when you sat down, and accidentally triggering the panic button?
My old man does that every once in a while with the keyfob on his GMC pickup when he falls asleep on the couch with the key fob in his pocket, and then after hearing his alarm wailing outside, he comes running half-awake up the stairs like a madman yelling... "they're stealing my F%$kin truck, those B%^tards!".... only to have his frantic lunacy thwarted by my families laughter.
Old Jun 2, 2009 | 01:57 AM
riflydon's Avatar
fxxk my life, I was holding the stupid keyless entry on my hands .... soooooo mess up; i have finals next week...
Old Jun 2, 2009 | 01:59 AM
riflydon's Avatar
is that suddenly it would scream? Coz i am not really sure is the battary. Anywayz, thanks 4 your suggestion. I would change the stupid battary first... btw, is there any possibilities despite the battary problem?
Old Jun 2, 2009 | 02:44 PM
riflydon's Avatar
push push, is that firmly about the battary?
Old Jun 2, 2009 | 02:53 PM
LjN_728's Avatar
If your car's parked in the garage, just leave the trunk partially open. That way the alarm can't reset. If all else fails, remove the fuse.
Old Jun 2, 2009 | 03:07 PM
riflydon's Avatar
but ... how is the solution ... is that really the battary or the alarm itself ??
how much to fix the alarm in stealership... i'm really anxious about it, thanks anyway!!!
