need help car wont start after sub installed
Old Jun 9, 2009 | 07:31 PM
PeterUbers's Avatar
Originally Posted by g35couture
ok guys, first of all thanks alot for your help guys. i got the sub up and running today everything works great but my car still wont run unless i give it some gas i thought it was my alternator so i disconnected my battery and reved up the engine. then i thought it could be the battery so i went to recharged it. still the car will start but it will shut off right away UNLESS i give it some gas then its drivable. what could be the problem?
does it struggle, or does it start up right away like normal and then die?
Old Jun 9, 2009 | 07:48 PM
Manual G's Avatar
The problem will go away on its own or do the "Idle Volume Air Re-learning procedure."
Here's the link.
https://g35driver.com/forums/engine-...messed-up.html
Old Jun 10, 2009 | 04:22 PM
g35couture's Avatar
it will start up right away like normal then die... could it be a bad alternator?
Old Jun 10, 2009 | 04:36 PM
Manual G's Avatar
I don't think its the alternator. The car will stay on as long as he taps the gas on startup. The ECU needs to learn the idle because it was reset when the battery was disconnected. If I am wrong please correct me. There are some infiniti techs around here that can step in with some info.
Old Jun 10, 2009 | 07:38 PM
PeterUbers's Avatar
Why would the ECU need to re-learn the idle just b/c the batter was disconnected? i've disconnected 100's of batteries from vehicles of all sorts and never had to do this. Perhaps i would believe this if something interefered electrically with the ECU directly -- like something related to his radio ...
Old Jun 10, 2009 | 08:04 PM
Manual G's Avatar
It happens to me every time I disconnect the battery for long periods of time. The car starts up and dies unless I give it gas. After a day or two the issue goes away.
Read post 9 and 13
https://g35driver.com/forums/g35-sed...edal-tapd.html
https://g35driver.com/forums/intake-...e-install.html
https://g35driver.com/forums/team-21...ierd-idle.html
Old Jun 10, 2009 | 08:32 PM
PeterUbers's Avatar
I think ManualG has your answer.
Old Jun 11, 2009 | 05:55 PM
g35couture's Avatar
Old Jun 11, 2009 | 06:40 PM
johnjohn077's Avatar
I have same problem when I have my battery disconnected for a long time. Like Manual G said it goes away after a few days.. or you can try that procedure.
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
ghost_g35
Aug 7, 2015 10:31 AM
kenthung
Jul 21, 2015 05:56 AM
