Double din in G35 Coupe
Old Jun 11, 2009 | 04:37 PM
kparlett's Avatar
Well i have a Kenwood DDX6019 Double Din that im planning on putting in my 05 G35 Coupe. I also have the dual function controller and faceplate on the way, but my question is if anyone know if there is a wiring harness for the Kenwood to the g35? Or if im gonna have to connect each wire one by one. Does anyone know where i can find a step by step instructions for the install? Ive done searches...
Thanks
Old Jun 12, 2009 | 01:11 PM
kparlett's Avatar
anybody?
Old Jun 12, 2009 | 02:18 PM
tiguy99's Avatar
Funny, I just did a quick search and came up with this
https://g35driver.com/forums/audio-v...ll-i-need.html
this
https://g35driver.com/forums/audio-v...-05-coupe.html
https://g35driver.com/forums/audio-v...8120-woes.html
Good luck... and remember to keep the search local to the forum section you're interested for the best results
Old Jun 12, 2009 | 04:52 PM
PeterUbers's Avatar
stickies on DDin conversion are easily available...
also search "Double din," "metra harness"
all within this forum
Old Jun 13, 2009 | 01:46 AM
kparlett's Avatar
thanks tiguy
Old Jun 14, 2009 | 07:54 AM
Gilley's Avatar
There is a wire harness adapter that you need. there is one for the Bose cars and one for non-Bose. You'll also need a Nissan antenna adapter and a PAC-Audio SWI-JACK to use the steering wheel controls. You will have to connect each wire of the harness adapter to your Kenwood, including the power antenna wire, but then you'll just plug the entire thing into the factory harness.
Old Jun 15, 2009 | 08:00 PM
kparlett's Avatar
is this what i need?
http://www.amazon.com/PAC-SWI-JACK-Steering-control-interface/dp/B0015G6LPQ http://www.amazon.com/PAC-SWI-JACK-Steering-control-interface/dp/B0015G6LPQ
also the antenna adapter says 2007 and newer im a 2005, do i need it?
Old Jun 15, 2009 | 11:34 PM
TroysG's Avatar
The only thing I disagree with Gilley on is the harness for bose and harness for non bose... both will work. one will work better than the other depending on your deck
if you go with metra/best kit parts look for 7550 or 7551 if you get a deck HIGH VOLT PREOUTS <-- very important - 4volt or better ONLY - I believe the antenna adapter number is 9 (ie best kits uses part number BAA9).
if you have any more questions. PLEASE search first as I has gone through the wiring harness on numerous occasions. search "7550" or "7551" + "harness" I'm sure a bunch of threads will show up.
if those don't sort you out feel free to pm me
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
