HELP!!! Air bag is flashing.
Old Jul 15, 2009 | 08:53 PM
Slyding_G35_03's Avatar
Unhappy HELP!!! Air bag is flashing.
Hi guys, I took out my radio and and put it back and the airbags is flashing. Did someone have this problem before? I pretty much put all the wires and check and re-checked the wires and everything is connected. I had the engine light on but it went away after recharge the battery. Is the airbag flashing had something to do with the battery? pls help.
Thanx in advance.
Old Jul 15, 2009 | 10:16 PM
PeterUbers's Avatar
If you disconnect the negative battery terminal for 10 minutes and re-connect it, do you get the same airbag light?
if so, there is a short or a circuit problem somewhere and it's most likely related to the radio power circuit -
Do you have an aftermarket stereo, or the OEM stereo?
Why did you take the radio out in the first place?
Old Jul 16, 2009 | 02:28 AM
I have my factory stereo. I took out the radio coz' i was gonna have it painted but change my mind after i took it out. i disconnected my battery for more than an hour and still dsame. I know if I go to the dealer it will cost me big bucks for just this I guess
Old Jul 16, 2009 | 02:36 AM
O HELLA JDM's Avatar
ME TO SAVE THE DAY
THREAD -->
https://g35driver.com/forums/repairi...g35-coupe.html
HOW TO -->
Originally Posted by SFLG35
this is a little easier
To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
Old Jul 16, 2009 | 02:47 AM
thanx. just found that and it works.. Thanx again
Old Aug 10, 2009 | 08:34 PM
Jamaica2G's Avatar
this one gives the full diagnostics after that point...
https://g35driver.com/forums/audio-v...or-bypass.html
KruZZe
Feb 27, 2023 05:04 PM
KallDay86
Jan 8, 2016 12:42 AM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
