Which Sub would knock harder?
Old Jul 17, 2009 | 02:36 AM
Nimar's Avatar
Hey guys, basically my question is would a 15" audiobahn sub seen here : http://www.onlinecarstereo.com/CarAu...roductID=15443
be better with the appropriate amp
OR
Two 10" JL subs?
http://www.onlinecarstereo.com/CarAu...roductID=12512
Old Jul 17, 2009 | 02:39 AM
Gu3s5who's Avatar
audiobahn sucks... JL too expensive and everyone has em... get elementals or something else classy
Old Jul 17, 2009 | 09:01 AM
G35pwrd's Avatar
What type of music do you listen to? If you listen to rock, 10's. If you listen to rap, 15. If you listen to 'everything' 12's. As for what company for sub, listen to a bunch of different ones at stores and see what sounds good to you. Don't go by brand or dollars, what do you like the sound of??
Old Jul 17, 2009 | 02:39 PM
blazeplacid's Avatar
how much room do you have?
thats the key
if you have enough room for a 15" go for it
Old Jul 17, 2009 | 02:44 PM
The Stimulation's Avatar
It's actually about the enclosure design. Ditch audiobomb, JL is good, sure its overpriced but you have quality. eD, eh, no thanks.
If you have a coupe, only way you're getting in a 15 is if you fire the sub upwards, make sure you got enough space, probably have to take out the spare tire and use the spare tire well as part of the enclosure.
In the sedan, it's no problem, I'll be doing a 15" in mine, heck I was considering doing an 18" in mine.
Old Jul 17, 2009 | 05:18 PM
Nimar's Avatar
I listen to everything, but mostly rap and techno more specifically electro, so i should get two 10s? I also have a coupe and I am not looking to take out the spare tire.
Old Jul 17, 2009 | 05:45 PM
Amount of subs, size, etc, dont matter. It's whatever fits in your ride with the proper air space.2 10's would be fine though.
Old Jul 17, 2009 | 06:06 PM
Bucszilla's Avatar
Get this instead, you will only need ONE: http://www.onlinecarstereo.com/CarAu...roductID=18357
Best sub I've ever heard along with the IDMax
I would be skeptical getting anything from a website that is not an authorized dealer...you can end up getting defective items with the serial numbers scratched off...
Old Jul 17, 2009 | 06:09 PM
better off with the type R IMHO. If you want something that will save you money and sound good Mach 5 Auido's IXL will do the job
Old Jul 21, 2009 | 06:59 PM
jumpnswish15's Avatar
has anyone ordered from onlinecarstereo because i was thinking about getting a pair of Jl tw5.
Old Jul 21, 2009 | 07:18 PM
mloid025's Avatar
JL for sure
Old Jul 22, 2009 | 10:49 PM
MileHiG35's Avatar
I bought a soundstream tarantula amp from them a year ago and it still works great
Came with original box and manual as well as registration card
Old Jul 22, 2009 | 10:56 PM
elayman's Avatar
I personally wouldn't.. with a rating of 4.15, it seems like more than half of the customers weren't happy
http://www.resellerratings.com/store/onlinecarstereo
Old Jul 22, 2009 | 11:19 PM
ClearBra_Guy's Avatar
To actually answer your question...the two tens will produce more sound. They have more cone surface area and with good power will kill a single 15. It makes no difference what type of music you listen too. That has always been a poor and false method of picking subs. Its all about enclosure design. Even the sub plays little part as long as you buy something decent.
Old Jul 23, 2009 | 12:45 AM
More cone area does not mean it will produce more sound...it's also difficult to describe the difference when using two different subs...there are other factors...I have proven people wrong with this theory many times. I used to have a single 10" sub in an utterly small enclosure with around 700w going to it and it got louder than setups with a pair of 12's. I didn't just use the human ear to measure the difference since that would be inaccurate, I used a Term Lab and did several runs. In addition, I was running a sealed enclosure as opposed to ported with some of the others I tested and I still had more output, so the theory of ported = louder is not always true, however, if you use the same sub, same vehicle, then yes ported will be louder.
The factors involved are the subwoofer itself, the enclosure, and the vehicle...different vehicles will have different cabin gains. Some subs are better than others, thus the reason why the sub makes a difference and the enclosure itself makes a huge difference.
Besides that, a single 15" has more cone area than two 10" subs.
Two 10's have a total cone area of 157 sq. in.
A single 15" has a total cone area of 176.625.
reaper76
Sep 20, 2015 11:59 AM
Paragham
Sep 15, 2015 12:04 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
INVADER_6MT
Sep 3, 2015 01:47 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
