Metra 7551 and F90bt questions
Old Aug 10, 2009 | 09:13 AM
bina12834's Avatar
so im trying to figure out which way to plug these RCA jacks together. i know which pair goes with which, but i have no idea what colors to match up....can anyone help? also when using the RCA jacks, does that mean i dont have to do anything with the grey/purple/green/white speaker wires coming out of the one f90bt harness?
Old Aug 11, 2009 | 08:49 AM
bina12834's Avatar
noone?
Old Aug 11, 2009 | 09:27 AM
Manual G's Avatar
https://g35driver.com/forums/audio-v...70-7551-a.html
Old Aug 11, 2009 | 09:35 AM
bina12834's Avatar
thanks, but the back of the metra package says that. i just dont know which color to plug into which color. like which colors(red and white) are positive and negative on the f90bt haress? im going to assume red is positive and white is negative, but i just want to make sure.
Old Aug 11, 2009 | 09:45 AM
Manual G's Avatar
I think the positive and negative speaker wires are connected through the harness. For the RCA cables, just make sure they match.
White - Left front
Grey - Right front
Green - Left rear
Violet - Right rear
Old Aug 11, 2009 | 09:55 AM
bina12834's Avatar
White - Left front
Grey - Right front
Green - Left rear
Violet - Right rear
did you even look at the picture i posted?
the violet and green RCA's need to plug into red and white RCA's....how do i know which color plugs into which color? the f90bt manual doesnt specify which color(red and white) is pos and neg
same thing with the white and grey RCA's...they need to plug into red and white RCA's....what color matches up with what color?
Old Aug 11, 2009 | 10:17 AM
Manual G's Avatar
The positive and neg. wiring is connected at the harness and has nothing to do with the RCA cables.
Old Aug 11, 2009 | 10:19 AM
bina12834's Avatar
sorry i meant left and right....i dont know why i said pos and neg
is red left and white right? is red right and white left? i dont know...the manual doesnt say
Old Aug 11, 2009 | 10:21 AM
Manual G's Avatar
Let me check.
Old Aug 11, 2009 | 10:22 AM
bina12834's Avatar
Before we go further, what is your setup (radio, speakers, amp).
stock bose system...hence the need for me to use the 7551 vs. the 7550 metra harness
Old Aug 11, 2009 | 10:25 AM
Manual G's Avatar
Red = Right
White = Left
Old Aug 11, 2009 | 10:27 AM
bina12834's Avatar
thanks!!
and you got this info from where?
Old Aug 11, 2009 | 10:28 AM
Manual G's Avatar
Its the standard for RCA cabling. Its the same for everything. I have books on car audio.
Old Aug 11, 2009 | 10:31 AM
bina12834's Avatar
duh!!! wow....i dont know why i thought car audio RCA's were any different than any other RCA's....wow....now im embarassed.
why would metra not just make their plugs red and white, since RCA plugs are standard red/white everywhere else?
Manual G's Avatar
Are you doing the hardware bypass on your F90bt?
