Add Aux input to stock unit with factory XM
Old Jul 30, 2004 | 05:47 AM
Supracool03's Avatar
How do you add an Aux input to the stock head unit with the factory XM unit installed? I really dont want to use an FM modulator. The pac-audio unit will not work if you have the factory XM unit installed. Any suggestions?
Thank you
Old Jul 30, 2004 | 12:54 PM
god_of_cpu's Avatar
StreetDeck.com Developer
Re: Add Aux input to stock unit with factory XM
You could splice into all the wires for the aux input cable and the satellite cable into a relay that would be switched by another switch you would have to install. I can't garuntee this will work, but in theory it should.
If you do end up going the carputer route, you can add an XM PCR unit to it for $50 that would replace your stock satellite system, which I'm sure you could probably sell for more then that.
Old Jul 30, 2004 | 02:02 PM
KPierson's Avatar
The outputs of the sat box are balanced if I remember right, so you can't splice directly into it, you need a converter to make your unbalanced signal balanced.
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
EnCr1pt3d
Jul 8, 2019 02:48 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Cacoepy
Aug 3, 2015 01:09 PM
