Anyone replaced their stock sub?
Old Aug 27, 2009 | 08:22 PM
Pmpjuce06's Avatar
thinking of replacing my stock sub. 04 bose premium. Thinking of going with this:
http://www.shopatron.com/products/pr...r=92070/1451.0
Old Aug 27, 2009 | 08:32 PM
Mustang5L5's Avatar
With a stock headunit and amp setup though?? Isn't that like buying a HD tv and playing VHS tapes on it?
Old Aug 27, 2009 | 09:06 PM
NjMatteSedan's Avatar
i wanna put an EV speaker in place of mine for crazy vocals
Old Aug 27, 2009 | 09:34 PM
skull_leader's Avatar
i replaced my stock sub for the 8" jl sub... i also installed an amp to power it... i just need to sound proof my trunck. it sounds better than stock... cheap easy mod for sound.
Old Aug 28, 2009 | 12:23 AM
Pmpjuce06's Avatar
very true...i am planning to go d.d. soon in the future, just wasnt sure if I needed to upgrade the amp along with the JL sub.
Old Aug 28, 2009 | 01:28 AM
yea the stock amp is garbage
Old Aug 28, 2009 | 01:55 AM
geesteezd's Avatar
i gotta see/hear this dave!
Old Aug 28, 2009 | 05:08 AM
Gettinby's Avatar
I replaced mine with 2 JL Audio 10' W6's with a Alpine 500w to each sub. BIG difference.
Old Aug 28, 2009 | 09:48 AM
Pmpjuce06's Avatar
which amp did you use?
Old Aug 28, 2009 | 06:23 PM
Cali_G35's Avatar
what's VHS?? lolz..
Old Aug 31, 2009 | 07:16 AM
im just using a 200w fosgate amp... its small enough to be mounted behind the seats in the trunk... a little to much power i had to turn the gain down alot. but atleast i know i more power if i need it.
Old Aug 31, 2009 | 03:13 PM
Originally Posted by Cali_G35
what's VHS?? lolz..
lol wow, vcr cassettes, the ones before dvd came out
Old Sep 3, 2009 | 08:17 PM
Skyfox16's Avatar
Hey, did you have to run the power wire from the battery to the amp, and then do the ground wire? kind of a noob question, but does our car have an amp in the back for the speakers?
Old Sep 5, 2009 | 08:39 AM
Gilley's Avatar
The Bose system has a small amp in the trunk.
If you're adding an aftermarket amp, you must run new power wire for the aftermarket amp to the battery. The power wire for the Bose amp won't work in that application.
Old Sep 5, 2009 | 08:18 PM
Bucszilla's Avatar
Can you run that as a "Free-Air" sub?
If so, I'd def get one...I have a 15" T1 in the trunk, but having that 8" JL in-cabin would be a nice add on. I just might do it since I have an extra Fosgate amp lying around.
*EDIT* I just noticed after posting the free air resonance is 34Hz...I am about to order it now!
