does the bose need to be rewired for the new HU?
Old Oct 22, 2009 | 08:03 PM
akachi's Avatar
i'm getting two different answers from two installers...
one says yes, my bose needs to be rewired because the headunit already has an amplifier.. and that i dont really wanna amplify and amplifer.. i would probably blow up my bose amp or factory speakers
one says no, the new radio simply sends the signal to the oem amp as the oem radio does.. you use the line outs from the radio to feed the bose amp. no preamplification.. but some nissans don't like that signal, so you can either buy an expensive bose adapter, or actually wire in using the pioneers amp. in that case, yes amplifying an amp, but works just fine. only downside is a little louder volume level. but most nissans you dont have to resort to that.
so for people with bose and aftermarket headunit, did u have to get your bose rewired?
Old Oct 23, 2009 | 01:33 AM
anmblackG's Avatar
new h/u and Bose speakers
Had the audio shop install a Bose wire adapter in order to have the proper volume control. Without it, if you increase the volume it doesn't sound loud enough. Then it abruptly becomes too loud.
Old Oct 23, 2009 | 03:03 AM
akachi's Avatar
so i would have to get that bose wire adapter and that will fix the problem? no need to rewire according to my friend?
Old Oct 23, 2009 | 03:47 AM
pfarmer's Avatar
Your new head unit most likely has unbalanced RCA outputs and the Bose has balanced inputs. You need a couple of balance transmitters to do it correctly. On the other hand your amp in the Head Unit may be ok to use with the stock speakers and you may want to check that out.
Old Oct 23, 2009 | 10:26 PM
anmblackG's Avatar
I did not have my stock speakers rewired. Just using the Bose adapter with a slightly more powerful amp in the aftermarket headunit and it sounds really good, very clean, with a little more punch than the oem h/u. The stock h/u doesn't have RCA cables to the speakers. It has a thin ribbonlike set of wires. That is Bose for ya. I strongly suggest having an audio shop with experience with G35s. There is too much potential for something to not work properly.
Old Oct 24, 2009 | 03:17 AM
akachi's Avatar
from what i hear.. i need to get the metra harness kit 70-7551 which is for bose and that is basically what i need, correct? i'm planning to get the Pioneer Z110BT.. since the z110bt is 4v preamp outtage, that kit is what i need.. correct me if i'm wrong..
Old Oct 24, 2009 | 07:05 AM
pfarmer's Avatar
The Bose uses balanced inputs instead of unbalance RCAs because that is the best way to do things with a remotely located amplifier for noise reduction. Depending on year I think you would find the power of the amps to be similar. The reason is that most HU amps do not use a dc to dc converter and therefore the rail voltage is the system voltage. There is a reason why most seem to be rated close to the same value (about 22.45 watts rms per channel utilizing perfect components and 4 ohms). The maximum would be roughly double this assuming the same 13.4 volt supply or about 44.9 watts rms again assuming perfect components and a 2 ohms load. Note the magic rms value of 22.5 watts rms per channel for many head units.
Basic formulas are:
Vpp = 2 x battery voltage
13.4 x 2 = 26.8
Vrms = Vpp/(2 x sqrt of 2)
26.8/2.828 = 9.4766
P = Vrms2/R
89.8059/4 = 22.4515
Double this for 2 ohms.
As a side note for other possible wiring modifications (you guys knows which mods I mean). On such a unit, that is one that doesn't use a dc to dc converter the maximum output will follow rail voltage which is system voltage.
On a system with a dc to dc converter a good regulated unit will have a stable rail voltage as long as the system voltage is above the reference operating voltage of the regulator. For example a typical 9 volt regulator will output 9 volts anywhere from about 11 or 11.5 volts upwards to 28 volts or so. Therefore any perceived sound level benefit will most likely be coming from a poorly regulated HU and not an amplifier utilizing a dc to dc converter.
No 'blooming' should be present with voltage changes on such a system.
Old Oct 24, 2009 | 08:11 PM
portuguesepride's Avatar
just wondering did anybody else have problems with their factory sound system, for me it would give out whenver I braked and took off quickly....like the speakers on the left would not gve anything out...then upon brake suddenly or taking off they would come back in and the ride side would give out
Old Oct 24, 2009 | 08:36 PM
pfarmer's Avatar
I believe this is possibly a common problem reported by many others with similar cars.
Old Oct 25, 2009 | 06:06 PM
silver64bh's Avatar
same problem here
i have 2004 G35 coupe and i am suffering from the same
the sound is going when i accelerate and then it comes back when brake (specially the left side speakers)
some times the sound it totally lost before it commes back again
can anybody help?
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
JoeMac
Sep 28, 2015 12:28 AM
JustinMKN1
Sep 18, 2015 03:40 PM
