Best replacement for crackling tweeters
Hey guys.
I am about 5 months into G ownership and I'm trying to sort out the little annoying problems with my car. One of these problems is that certain songs, particularly ones with strong mid/bass, make one my tweeters crackle. I know that this shouldnt really be happening, as the tweeters should only see the high freq sounds, but it is. I am not a big audio guy and am otherwise more than happy with the factory bose system on my car. I was just wondering what the best value tweeter would be for relatively simple replacement. I am not looking to install an amp or substantially improve the sound, just want to know if there is a better set of tweeters than the stockers for the money. Thanks.
I've actually been searching for the same thing but am having trouble finding tweets to match the 2 ohm resistance of the factory bose. Here's ones that I'm going to try that should work in the stock locations plus they are 2 ohm:
http://www.sonicelectronix.com/item_...BL+GTO17T.html
Big audio guy and your happy with a Bose system?
No offense but Bose is over priced and even though its a bit better than factory it is no way as a good as a real aftermarket system. Even in home theaters Bose is crap..
GL with your search though..
Good point. For me the Bose system is definetly lacking in the 'Highs' department so I'm hoping with the 2 ohm I won't have to set my treble at +5 ALL the time on the HU. And yes, there is a reason why NO BOSE SYSTEM has ever been THX certified.. actually they won't even submit it for testing which is fishy to me. I mean, most supposed 'high end brands' would want that certification for marketing purposes. Bose just knows right off the bat they won't make the cut.
Ok update!!! I just installed my POWER ACOUSTIK NB.1 TWEETERS in the factory location! Wow wow wow what a differance in sound! At 15 on sound level on factory head deck these teeters sound awsome! It makes the stock tweeters sound like the don't even work! I got these tweeters off eBay for 11.34 shipped!! I took a sound clip at same level before and after on my iPhone just need to figure out a site to upload it on to post here! Anyone know a site to use? I also have install photos I'll post later!
They have a crossover on the tweeter just like stock! just removed the plug snipped the wire about an inch from the stock tweeter an used red barrel connectors and done! then i used the double side tape the tweeters can with to stick them to the stock bracket that holds the stock tweeter in place!
Well with my car it was a nice differance!! Both my friends that has an 06 an 03 G35s where like that's nice! They ordered the same tweeters now I have to do there cars lol! These handle 50w Rms each and 100 watts peak each I don't think you will max these out! I was listening to techno and rap everyday and have my head unit at 20 to 25 with no issues yet! The louder u go the better they sound! I did a before and after sound! With out the aftermaket tweeters the stock system sounds a little muddy but they bring the clean it needs!!!
