03 metra single din install. A/C semi working
Old Feb 21, 2010 | 08:11 PM
usmcgetsome's Avatar
I did search but the other members issues were not similar to mine. This is after the new stereo kit went in. I did all the wiring myself and hardware as well. Everything was put back in as i took it out execpt for the one WHITE PLUG.
Ok my fellow "G" brothers, I installed my single din 7in flip screen. All went well and all the buttons work except for the temperature up/down switch. Currently all the other buttons work for the hvac to inclue all the speakers and radio. I plugged in 3 of the 4 factory harness into the supplied metra wire harness. There is one that i have no clue what its supposed to do. Has anyone run into this issue?
or where does that last white plug go.
Old Feb 21, 2010 | 08:34 PM
TwilightSedan's Avatar
Sounds like the double din kit is hooked up. There should be one harness coming off the metra ac controller. If the other buttons are working then you have it connected, I would contact metra or return it and swap the metra ac controller. May be a defect. The AC controller only works off of one of the harness's. Sounds like you got a bad Metra AC controller. I'm going JDM. It's twice the price but it works and looks better. Try checking the wire harness that comes off of where the AC Controller is. Make sure you haven't bent a spade. From what I hear they are very flimsy.
Old Feb 21, 2010 | 10:59 PM
will check tomorrow. I do remember when i hooked it all up it set up both drivers and passengers to 75 degrees and on a/c. Its possible that the harness isn't sitting properly. Will look at it tomorrow.
Old Aug 29, 2010 | 12:12 PM
zbrabach420's Avatar
i just ordered my single din head unit to fit in my double din kit. is there a certain wiring harness i need?
Old Aug 29, 2010 | 12:38 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
2005-2007 Bose - Metra 70-7551
2003-2007 Non-Bose - Metra 70-7550
2003-2004 Bose - PAC ROEM-NIS2
Old Aug 30, 2010 | 08:23 AM
blazeplacid's Avatar
did you buy the metra double din kit??
if so there is a jumper you may have to move
I believe its on pins 4-5 right now and it needs to be on pins 2-3, or something like that
the jumper is behind the ac controls where the harness goes in
**edit**
crap just read original post date...
Old Sep 6, 2010 | 08:37 PM
what do you mean by "with bose system"?
Old Sep 6, 2010 | 09:24 PM
i plan on keeping the stock bose amp and speakers for now, but i just dont understand what harness i need to get
Old Sep 7, 2010 | 03:53 AM
There's a shopping list sticky at the top of this forum that'll tell you everything you need.
champppy
Mar 31, 2020 12:25 PM
WillisFL
Dec 29, 2016 08:56 AM
kd03g99
Jul 30, 2015 11:24 AM
Rehman2009
Jul 27, 2015 03:23 AM
