Quick question about metra kit
Old Apr 6, 2010 | 04:26 PM
sticktodascript's Avatar
how do i keep my stock navi with the metra kit? i know the kit sucks but its holding me over till i get a jdm. I have everything installed, but for some reason i cant get the actual navigation block to fit. Theres nothing to screw
Old Apr 6, 2010 | 04:43 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The first step is to provide people who may want to help with information so they can help you.
What year?
Coupe/Sedan?
Pics of what's not fitting would probably be best, and answer both above questions.
Old Apr 6, 2010 | 04:48 PM
Oops sorry i should’ve continued my prior posts that explain everything.
I have an 03 coupe with stock nav and Bose. I got the metra dash kit and a pioneer 3200 DVD head unit. i got everything fitted except for the stock nav. The button are in place but with the metra kit, i see no place to secure the navigation assembly
Old Apr 6, 2010 | 05:47 PM
bump
Old Apr 6, 2010 | 06:14 PM
Not sure if others with 03/04s with nav & ddin used the Metra kit or not, but there's always a way to mount it if it fits. Hot glue, aluminum sheets, JB weld...
Oh, and before you go attacking it with a dremel or whatever, you may try calling Metra's help line: 1-800-253-TECH
They don't say that navigation DOESN'T fit, so, they should be able to help you out.
Old Apr 6, 2010 | 11:16 PM
lol ve been on hold with metra tech for 2.5 hours no answer lol i gave up
Old Apr 22, 2010 | 11:27 PM
trevorwhopkins's Avatar
I just went threw this problem a few months back.
Good fing luck lol. The Nav wont stay mounted, and when it does the fit looks goofy. I was pretty psyched about using a pop up screen as my rear monitor for movies and nav, and I do this for a living, and I couldn't figure it out without fabricating some kind of crap.
That being said I spent two days planning this, and asked around at work. G35 metra's are common. keeping stock nav, theres a few threads around the net, but i couldnt do it without a bunch for time than I'm patient enough for.
Instead I decided to just get the pocket thats in stock g's and put a screen inside it. It won't do the impressive slide up by button, lol, but its a screen. I plan to use an Archos 5 MID. It's sort of like a cheaper older ipad, looks like a 5" nav screen with Android operating system does internet movies games, google navigation yadda yadda.
Old Apr 23, 2010 | 10:36 PM
lol thanks bro! i tried drilling holes into the kit and rigging someting but it came out terrible lol so i just spent exra and got the jdm kit
Old Apr 24, 2010 | 05:01 AM
Thanks for posting the update, I'll update my Ddin post to show that you need the JDM to do it.
Old Apr 25, 2010 | 05:01 PM
metpage's Avatar
you can usee the nav screen with the metra kit however, you will end up having to fabricate a mount for it as the kit doesnt have one for it. I believe the kit was inteneded for non-nav G's. If you have a nav G then go with the JDM kit even though its 3x more expensive, in the end it will look better
Old Apr 25, 2010 | 09:32 PM
3x? Hm, maybe if you get the 1/2 off deal from crutchfield if you buy a headunit with it, otherwise it's maybe 1.5x as much.
Old Apr 25, 2010 | 09:53 PM
Ig35's Avatar
i had the metra kit also and i was not able to get the oem navi to fit. the navi buttons would sit pretty tight on the kit and getting the screen to mount onto the kit just didnt happen for me. i do remember i had one screw that would line up with the controls but the other side didnt. i agree with metpage that you will have to rig something up to get the navi to fit.
Jusseth
Sep 13, 2020 12:25 PM
Th611
Oct 27, 2015 03:48 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
