Installing Double DIN clarion, works but no audio
Old Apr 21, 2010 | 10:54 AM
MarkoG35's Avatar
The only thing that i can think of, is i did not transfer the wire of the climate control into the new kit i bought, because i forgot to, but regardless, i checked the Double DIN for any mute all keys or whatever on the interface and nothing. So my question is, is there anything that plug for the Climate control have to do with the audio not playing? like is there an audio wire in that lil plug that i have to hook up? Would that be the reason for me not hearing my audio? since i for sure checked my connections and such. And it is a brand new Clarion.
Old Apr 21, 2010 | 11:02 AM
blazeplacid's Avatar
have you tried using a CD? Does the audio not work on FM only?
do you have amps installed?
do you have factory bose?
ONCE I made an idiot mistake....my eclipse had a separate cable for RCA plugs. i forgot to plug that harness into the radio.hahha.
Old Apr 21, 2010 | 11:19 AM
MarkoG35's Avatar
Idk man.. i think its the climate control thing, and yes i did.i used a CD first then radio nothing..my stocks in now
Old Apr 21, 2010 | 11:25 AM
climate control does not effect an aftermarket radio
Old Apr 21, 2010 | 11:36 AM
MarkoG35's Avatar
No amps or factory amps..idk i think its that cuz i noticed they have somethin to do with my dash lights that pop up.
Old Apr 21, 2010 | 12:55 PM
Canadian G's Avatar
Are you sure you don't have a factory Bose amp? Did you try hooking up the remote wire (usually blue/white) from the head unit to the blue/white wire on the harness adapter?
Old Apr 21, 2010 | 01:52 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Did you have Bose?
Did you install yourself?
Did you use the Metra 70-7551 or 70-7550 (or their equivalent) or PAC ROEM-NIS2?
Old Apr 21, 2010 | 05:04 PM
Minheeeme's Avatar
Plug in the remote wire.
Old Apr 21, 2010 | 09:26 PM
MarkoG35's Avatar
i used the Metra..i did not have Bose. im thinkin it is the remote wire too..idk what ive noticed too..once i do get it working..itll be tough to shove it all back down in there cuz thers that huge plastic peice blocking the wires places to move n turn..i just have the 6.5" bass with tweeter in the front doors and the 6.5" in the back doors n thats it..no lil 8" bose sub or nothing..doesnt say bose on my stock headunit..so who knows..ill try it soon..its just a hassle..but ive took it apart n back n forth so much i can take apart n get to the radio in less then 5 mins..kinda like nascar..for G35 audio..
Old Apr 21, 2010 | 09:49 PM
Minheeeme's Avatar
I just finished my install and noticed I experienced the same problem as you. Once I plugged in the remote wire, I got sound.
Old Apr 21, 2010 | 09:51 PM
MarkoG35's Avatar
howd u get all the wires to tuck well? i have too much..i guess ill deal with it once i get it workin good..and it was the remote? alright ill try it sunday..i dont have time to pull it all part..even tho its 5 mins hehe whats weird tho is i swore i either connected all the blue wires or i connectd 2 and taped off the other blue..hmm....
Old Apr 22, 2010 | 12:26 AM
I tucked my wires down the sides where I could. Made a lot of room.
And if you didn't have Bose, remote wire doesn't connect to anything.
You didn't answer if you had the Metra 70-7551 or Metra 70-7550.
Here's what I think happened -
You installed a 70-7551 harness on a non-Bose vehicle. Easy way to tell? Did you connect any RCA connectors to the new head unit? If so, go buy the 70-7550 harness and connect it up instead. The RCA outputs are unamplified and won't power any speakers.
If you didn't connect any RCA plugs to the new headunit, then you probably didn't clip the speaker wiring harness in soundly and it got disconnected when you put the headunit in.
Old Apr 22, 2010 | 07:26 AM
MarkoG35's Avatar
Well, i dont have BOSE so im pretty sure theres no factory amp cuz i didnt see any factory rca's there. And so i didnt use them, and i made sure the plug was good for the speakers since i just let the headunit sit freely while i plugged it all in etc..so idk
Old Apr 22, 2010 | 08:51 AM
So which harness did you use?
Did it look like this:
Or this:
Old Apr 22, 2010 | 08:53 AM
If it's the one on the top, you need the one on the bottom.
If you have the one on the bottom, you've got a bad headunit or your speakers are wired wrong.
