12W7 and JL 1000/1
Old Sep 23, 2004 | 10:58 PM
al503's Avatar
Re: 12W7 and JL 1000/1
good advice from 4080 about the cap. Skip it.
In terms of the electrical system, it won't handle a 1000/1 without mods. The 1000/1 has a 120 amp fuse IIRC. Your stock alternator is rated at 110 amps. I had my alt tested and it put out around 126 amps. Your's may be stronger or weaker but it'll be a minimum of 110 amps. Therefore, if the alt was just powering the amp, it will probably fall short. To compound the problem, your alt has to power the rest of your car.
The last time I looked into an upgraded alt, no one made one for the G. You may be able to have your's rewound but it only gives you more power up in the rev range and it'll suffer at lower rpms in most cases.
Have you thought of a 500/1 to power it instead? With 500 watts, you'll get around ~92% of a 12w7's potential. With a 1000/1, you'll only get around 95-96%. The extra drain is not worth it IMO.
Old Sep 24, 2004 | 04:34 PM
Birds04G35's Avatar
wow that sounds like the 1000/1 is not worth it. i just got it, havent installed the 12w7 yet because ive yet to recieve it. i think im going to return my amp for the 500/1. i dont want any problems. Thanks
Old Sep 24, 2004 | 07:13 PM
xlacrosse's Avatar
Dude the 1000.1 is a Excellent amp, and I would run it if using 2 w7's but otherwise the 500.1 would be perfect.
*ANTI G-Squad Member*
Old Sep 24, 2004 | 08:00 PM
Birds04G35's Avatar
alright thanks for all the help. im going to exchange my 1000/1 for the 500/1. "save alot of money =)". and when i get my 12w7, ill let everyone know how it sounds
xlacrosse: your cars damn nice, i like the front end and rims.
Old Sep 25, 2004 | 12:32 AM
al503's Avatar
I think he is running only 1 w7. The 500/1 will be plenty. Your problem with that setup won't be the sub or amp, but the rattles you are going to get when you crank it. It'll be time to invest in some dynamat and a bunch of foam for the interior.
Old Sep 25, 2004 | 12:36 AM
Birds04G35's Avatar
yea rattles will probably be my next project, although i had 1 12" Kicker L7 in there before, and 2 HE2's before that and the rattling wasnt all that bad. but then again im gettin a W7
is there a how to for the dynamat for the trunk area? or should i just have an installer do it.
Old Sep 26, 2004 | 02:23 AM
al503's Avatar
applying dynamat isn't rocket science but it does take a lot of elbow grease. The coupe is pretty decent compared to the sedan in terms of rattles. I'd go on ebay, get a 36 square foot bulk pack for ~$130. Install your sub, crank it up (after a little break-in of course) and listen for where the trouble spots are. Installers charge $40-50 per hour and it can take a few hours to do the trunk only.
Old Jul 7, 2005 | 05:09 AM
Mudi786's Avatar
well i just bought my 2004 g35 coupe wt 6500 miles 2 days ago and bought my 12w7 and 1000/1 amp today should have it installed by saturday i dont think i should have much of a problem going to add a cap just for that burst of energy that the w7 needs every now and then any suggestions besides downgrading my amp because not something i plan to do
Old Jul 7, 2005 | 07:31 AM
HOO-MAN?'s Avatar
Youll Blow Your Sub...hope You Have A Warranty!
Old Jul 7, 2005 | 09:24 AM
my_Gthang's Avatar
i have this set up 12w7 and 1000/1 and 450/4 for quite sometime now and i very, very happy with it, i do have a cap as well as an extra battery...and i also did upgrade my speakers, one more thing buy some dynamat or something similar you going to need it!!
Attached Thumbnails 12W7 and JL 1000/1-sm5.jpg   12W7 and JL 1000/1-jl4.jpg   12W7 and JL 1000/1-jl4.jpg
Old Jul 7, 2005 | 11:40 AM
Mudi786's Avatar
nice box im lovin it hey what are the specs on your box
never gone
May 17, 2008 04:04 AM
hurricanebsball
Jan 21, 2008 12:11 AM
gone
May 5, 2004 06:28 PM
LoveMyBSC
May 5, 2004 12:58 PM
