No Sound After Avic Z110bt installation
Old Jul 6, 2010 | 10:07 AM
Buddi's Avatar
ok .. for all you audio heads out there.. i need some major help... i installed my navi over the weekend.. and i ran into a few problems..
1. Can someone please tell me where do you connect the green parking brake wire.
2. Can someone please tell me where to connect the pink speed signal wire as well.
Now for the issue and the attempting results.
The navi was installed to where everything works... just that i have absolutly no sound... gps works everything.. just no sound period from the speakers... now i did the bypass so you can watch movies while driving.. and im thinking that might be the reason for the sound issue.. if ne one is familiar please.. help. thank you.
Old Jul 6, 2010 | 12:24 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
1) Ground it for the bypass.
2) Connects to the VSS wire - White w/green stripe, it's on the same harness that the steering wheel button wires come in on.
Sounds like you may have screwed up the bypass and grounded the mute wire without moving it. Make sure that you've moved it one spot over and tied it with parking brake, and then grounded both of them.
If that's not the problem:
Did you have bose or no bose beforehand?
What wiring harness did you use?
If Bose and 70-7551 harness, ensure it's wired like this:
https://g35driver.com/forums/audio-v...snt-quiet.html
Old Jul 6, 2010 | 01:54 PM
Buddi's Avatar
No.. i bought the other harness 70-7550.. and yes i have the bose systme.. could that be the reason why im not getting ne sound?
and yes i moved the mute over one spot.. but i tied the mute (yellow and black) and the green parking cable together with the black wire and grounded them into the ground provided with the other harness ( black and white cable)... and i am replacing my factory amp... (also when do this .. should i remove the stock amp in the trunk?)
please helppp.. would love to get this working.. what should i do ..
Old Jul 6, 2010 | 02:42 PM
If you're replacing the amp anyway, don't worry about the no-sound thing right now, since you'll run your own RCAs to the trunk anyway.
It sounds like your bypass is fine.
Removing the stock amp gives you more room for the other wires, so yes.
If you're not doing the amp in the next day or so, post up a pic of how you wired your 70-7550 to the Z10BT's harness, because even if you wired the high-level outputs to the Bose amp, you should get some sound.
Old Jul 6, 2010 | 02:50 PM
Buddi's Avatar
i dint ground the mute, parking and black wire to the car it self.. could that be the issue.. please respond asap.. would like to tackle this tonight so i can report back tamar..
Old Jul 6, 2010 | 02:59 PM
Buddi's Avatar
keep in mind.. nothing is grounded to the car it self.. could that be the issue... i connected all the wires according the color.. move the mute over one.. tied that to the green parking wire.. tied those two to the black ground.. and tied those 3 into with the amplifier ground.. i think i messed up somewhere there.. what u think?
Old Jul 6, 2010 | 03:02 PM
Buddi's Avatar
another thing.. where do i find the steering wheel harness to connect that pink wire for the speed ....
**lets say i needed to extend a wire.. is it possible to use some of the green parking break wire to extend the black wire so it can be grounded to the car?
Old Jul 6, 2010 | 08:03 PM
Okay, here's some of your issues:
Yes, the parking brake, bypass mute wire, ground from the Z110BT's harness and ground from the Metra harness, and the AMP GROUND all need to be grounded to the vehicle body. The metal frame around the radio is a good place to ground to the vehicle body.
I am not sure if the 70-7550 harness even has a wire for the AMP GROUND, if it doesn't you've got to find which wire it is using a wiring diagram and ground it.
You can use any wire you want to extend - wire's wire. Just don't get confused.
Old Jul 7, 2010 | 08:34 AM
Buddi's Avatar
HAHAHA.. i got it fixed.. the blue and white cable was not cennected under the electric tape i had.. the wires were broken.. i have sound now.. and the bypass still works.. but i have a lil distortion in my speakers while playing the radio stations.. the ipod is fine.. ne thing that can solve this matter.. either way im just happy to have some sound..
chinee
Jun 10, 2024 07:48 PM
willdogs
Dec 8, 2015 11:32 AM
ScraggleRock
Aug 11, 2015 10:16 PM
ghost_g35
Aug 7, 2015 10:31 AM
kd03g99
Jul 30, 2015 11:24 AM
