Double din units smaller than 7 inches.
I tried searching but counldn't really find much but has anyone installed a double din unit smaller than 7 inches with the jdm 05-07 dd kit anyone have pictures.
Well see ive noticed thats some of these DD units that people have the screen size is for example 5'8 or 6'2, candlestick what screen size is in that pic. Im just saying does the screen size have to be 7 inches? Would it be a problem if the screen size is smaller when installing with jdm dd kit.
If you cut the USB wire, you can shove the bare wires through a much smaller hole, but it requires a little bit of soldering.There's a little room around the hinges, but you're better off drilling the small hole and soldering it back together. Without cutting the wire, you're looking at a much bigger hole to get the USB plug through.
FS[NorWest]: 04 OEM Faceplate and CD/Tape Unit
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
