Amp Integration Piece required?????
Old Aug 16, 2010 | 05:20 PM
SIKHestG35's Avatar
Exclamation Amp Integration Piece required?????
I am getting a Pioneer AVH-3200BT radio hooked up in my 03 G35, and Best Buy said that I may need an Amp Integration Piece (Peripheral ISVE61). I was wondering if I could, cuz its kinda pricey, and if I do id rather buy it from online. Thanks.
Old Aug 16, 2010 | 05:53 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Looks like the same thing as the PAC ROEM-NIS2, about the same price too.
If you hook the regular 70-7551 harness up right, you'll get sound out of it, but if you ever want it to get up to full volume with the Bose amp, it's recommended. But still, you're best off getting rid of the bose amp instead of buying crutches to keep it working.
Old Aug 17, 2010 | 12:39 AM
Idkorcare's Avatar
You dont need it. I work for Best Buy myself and for awhile had my Pioneer DD running off the stock Bose system without any issues. If the rest of the Bose system is working fine it really doenst sound that bad either. All that piece does is lower the signal output but Pioneers have such a wide volume control range its pointless. By that I mean an Alpines volume goes from 1-35 and most Pioneer go from 1-62 so even if it maxes at 40 you have alot of adjustment. I cant remember if that radio maxes at 40 or not but you would still be fine.
I have installed for 10 years and done it first hand, if they insist you need it they are idiots.
Old Aug 20, 2010 | 03:34 PM
SIKHestG35's Avatar
thanks guys, will post the pix up soon
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
