Replacing Bose with DD, speakers all around - Advice on components, wiring needed
Oct 20, 2010 | 12:21 AM
  #61
UPDATE - System Installed
UPDATE
I got my system installed. I spent the better part of the October 10-12 on it.
Here is what I put in:
Pioneer AVH-P4200DVD
JDM Kit
Metra 40-NI10 Nissan Antenna Adapter
Metra 70-7550
Focal Polyglass 165 VR - front doors
Alpine Type-R SPR-17C - rear doors
Soundstream RUB4.600 - for door speakers
Zenclosures speaker spacers
Phoenix Gold XS2500
Xtant X124 12" sub
CLD Tiles in doors, trunk, rear deck
I have a 4 gauge power wire running to a distro block, with two 8 gauge wires running to the amps. I ran 4 gauge wires as ground to the rear seat brackets.
For a first time install, this took longer than I expected. But by the time I put the fuse in the power wire, it turned on and everything worked perfectly! Some fine tuning on the HU EQ and setting the gains on the amps. and everything is sounding great.
I still need to finish the amp rack, as I decided not to mount the amps to the backs of the seats, mainly due to how difficult I found it to get around in the trunk and work.
I will put pics up after this weekend when I finalize the amp rack.
The only way I could accomplish this was with the help of everyone's advice on the forum here. Wrathernaut, Eggyhustles, you two are owed a few beers. Hit me up if you are in Seattle area.
Thanks again to everyone. I wish I did this 5 years ago.
Reply 0
